Oil leak, help :(
Oil leak, help :(
Hey guys,
i was just doing an oil change, and i noticed a leak..... it appears to be coming down from the head area and collecting on the oil filter/oil cooler lines.....
I did a cam/headstud install about 3 weeks ago, but im not sure that caused it? i have resealed the valve cover gasket very well, and it's still leaking
Here is a picture of the oil drained, if it is indeed coming from the head gasket, it might have coolent in it... can you tell?
Thanks
-TJ
Thanks
-TJ
No i did not, i didnt know where to place it........... what was the path of the leak? because i just had the cam gear cover removed, and it was 100% oil free ........ so im guessing a cam seal leak would run down the that side of the engine.... correct?
I just had the cover off, i didnt inspect the cam seals, (can you see them with the gears installed?) , but i also didn't note any leakage in that area...... I assume it would leak straight down.....
i just found this:
could this be the issue......... Is the threaded area of the block have a passage way directly to high pressure oil?
When you install the arp head stud did you use an allen wrench and hand tighten the stud into the block by hand??
If so that could be your problem. That's what I did when I first install my arp HS. I went back and loosen the nut and tighten the stud using a rachet and was surprise to see how much more the stud could be tighten. I TQ the nut to 85 ft\lb. After a few days of driving the leak appears to gone or it's not leaking as much as before. Synthetic oil seems to sip through the smallest leak. I'm not saying that this is your issue but it seemed to help out the leak in my case.
What you have hear is a common problem, but that seems to be quite abit of oil depending on the time it took to leak that much. Replacing headstuds one by one seems to be the problem most of the time and it usually causes the oil to leak out the back of the head more so than the front. The advice I can give you is recheck the headstud torque values and make sure they are good. If they are all at the same value you will probably need to pull the head off check the flatness , clean it up and replace the head gasket. If you do replace the head gasket I recommend purcasing a good aftermarket gasket (Greedy, PowerEnter, HKS, ect.). I am not a big fan of the stock head gasket becaues of this, just my opinion.
Don't get to worried yet, keep an eye on your oil and keep off the boost until you truly determine if things are mixing. Usually they don't get mixed but that is quite a bit of oil even if it was for a couple of days sitting there becuase under boost it would leak alot more.
As for above, you can hand tighten the stud into the block but use a allen wrench and get it tight. This is where most people get mislead, it has to be tight (not finger tight) otherwise they have a good chance in loosening. I recommend 85ft lbs as well on the nut with cycling.
