check this out
Old Jan 20, 2006 | 10:40 PM
J!n K@z@mA's Avatar
check this out
well after my problem about the coolant hose (that goes to the turbo) leak that i already fixed. the engine sounds strange. i checked to make sure that i have enough coolant, no leaks etc. but the engine sounds weird. when i had the prob. i almost overheated the car. i swear i checked everything. any comments?
Old Jan 21, 2006 | 10:34 AM
walkedu's Avatar
What noises do you hear and when do you hear it? For example: Do you hear it at idle, initial start up, WOT, RPM??? We need more info to help you. To be sure, i wouldn't risk driving it anymore. If you are under warranty, take it straight to the dealer. If you have mods, find a mod friendly dealer 1st, or try to go back to as stock as possible.
Old Jan 24, 2006 | 07:51 PM
J!n K@z@mA's Avatar
i really don't know. the strange engine sound evry time i drive it at any rpm. instead of an aircraft sound, it's like smooth "gargling your mouthwash" sound
Old Jan 24, 2006 | 07:53 PM
advancEvo27's Avatar
did you pressure test the cap and the system to make sure of no leaks?
Old Jan 24, 2006 | 08:05 PM
J!n K@z@mA's Avatar
yes i did. evrything that needs to be checked i did. every test but still...
