alky pump output psi Q...?
Old Jan 21, 2006 | 08:17 AM
yesevo's Avatar
when i first install alky kit ..i remembered it reading around 120psi....after like 3months i check the pump pressure ....reading only 80psi...
is it still ok to run? seems like reading too low....
i got the new version2 alky kit
thanks !
Old Jan 26, 2006 | 08:52 AM
yesevo's Avatar
help!
Old Jan 26, 2006 | 09:44 AM
Evotech8's Avatar
Try flipping the dip switch #1 on the side of the controller box. It should raise the pressure at least 20psi. But if you originally had 120psi and now dropped to 80psi you might have a leak somewhere, pump requires re-priming, or the pump might be failing.
Old Jan 26, 2006 | 01:39 PM
yesevo's Avatar
Is There Switch #1 On Smc Version 2 ?
80psi Is Safe To Run?
Old Jan 27, 2006 | 12:46 PM
yesevo's Avatar
bump
