Guess my HP! Winner receives a pat on the back
What could I get for hp?
3" invidia TBE no cat.
3" o2 housing SS
SS header
feeling cheap
fuel pump 255 lb
hks hard pipe intake
hks hard pipe upper/lower
hks ssq
hks FMIC
93oc
05 RS considering my 10.5 hotside w/ flash
same eastscoast
3" o2 housing SS
SS header
feeling cheapfuel pump 255 lb
hks ssq
hks FMIC
93oc
same eastscoast
Originally Posted by C6C6CH3vo
hel if ino:
Did you manage to find an atm to test the 2step boost, was curious on the times. I took off - had to get home to tuck in the kids
Its kind of funny how things work out in the whp game
Here we have an excited customer obviously looking for good power delivery
Sadly, it was not to be
As a tuner, being able to "feel" and "hear" what a car is doing and having the experience to understand when a car is not right mechanically is what gives you the ability to get good results and avoid disasters
When tuning this car it was clear that the powert was not there given the mods, boost, timing and a/f - looking out the back of the car and seeing the tell tale bluw oil smoke was another clue
I personally conducted a compression test and found a week cyl about 28 psi lower than the others - a swirt of oil brought it right up to the others
on a 4 cyl car = you are not going to make good power on 3 cyls - sorry
My suggestion was to lift the head and hopefully its a head gasket
Obviously, you are at the track racing the car
Hopefully your next step is not pulling the entire motor
Sorry your car did not make the power you wanted but its not going to happen with a weak cyl
I had no issues with the tune, I love the tune, I love the power, I love the launch control, and the smooth idle, props Al. It should have made more, is all... As far as extracting it, who the hell knows
I hav always felt, since day one, that I had a slightly weaker EVO, than fellow EVO owners similar setups... maybe I just need to buy a 9, and have you tune that one right?
Originally Posted by hel_if_ino
Didn't find a damn atm, but the dood let me make a pass... I did ok, ran a 7.96@87 with a 1.72 60ft. I was actually bogging in the hole, didn't do that on the street but I guess I had more grip on the track, it was f'king fast though, almost beat a turbo mustang.
I ran a 8.045@88.739mph w/t a 1.798 60' (still havent changed stock catback)- I cant figure my ET in respect to mph - shifting?
1.72 60ft? Man I got to learn that 2 step. I may have to politely show up next week with $40 cash and some smoothies durring some down time.
damn, trap speed is high, your car sounds pretty damn fast, or maybe I just suck at driving....
Slow ET in respect to mph = loosing time between shifts
I think shifting speed has more effect on ET than mph
Moreover, I dont trust that track's mph.
... that is hella good with a stock catback and stock clutch.
10.5 Hotside alone gave me 0.27 sec in 1/8.
I think it may be the opposite, I shifted easy. Fast ET in respect to mph = quick shifting
Hotside, cams, stiffer WG act, and no boost leaks. My catback has been adulterated: I permanently opened the internal flapper and and beveled the 2.5 flange where it meets the catdelete- helped.
