SMC new alky kit coming soon
Old Mar 8, 2006 | 10:44 AM
  #46
johnjonfenomeno's Avatar
If you guys have an EMS and are running an electronic boost control this feature can easily be programmed in providing the fact that you are using the EMS to control boost.
Old Mar 15, 2006 | 09:00 AM
  #47
dadriva's Avatar
Any new word on this product??
Old Mar 15, 2006 | 10:00 AM
  #48
thatsMR2u's Avatar
Originally Posted by SMC
Hey Guys-
Sorry for the wait on the safeguard.......it's been a freakin zoo here. It looks like it will be a swap to the new v3.0 controller with safeguard built in. This makes for a much neater look than adding another box to graft into the old controller.
The 3.0 controller will have an extra dial to set the safeguard point. (for example 20 psi) If you reach 20 psi and the controller does not sense an alky pressure signal from the pump the safeguard will close a solenoid valve that will mount inline between the wastegate and boost controller. (factory or otherwise) When the valve closes the boost will drop to wastegate spring level. Sound good? Any input from you is appreciated. Will put it up on the website as soon as it is available....and after my main vendors have tested it. Thanks for your patience!
Hope to have prototype pictures up soon.......
Old Mar 15, 2006 | 12:11 PM
  #49
dadriva's Avatar
Thanks for the info.
Old May 9, 2006 | 03:36 PM
  #50
forum04pl's Avatar
bump for more info... this should have been out a few weeks ago
Old May 9, 2006 | 03:51 PM
  #51
Blitzbaster02's Avatar
still not out yet, i just called! He said 3 more week!!!!!
Old May 9, 2006 | 04:24 PM
  #52
Ultimate CC's Avatar
Snow Peformances is available
Old May 9, 2006 | 05:52 PM
  #53
EvilBlueEvo8's Avatar
He always says 3 weeks. Told me three weeks three seperate times with weeks in between. I'm starting to think there really is no failsafe.
