RNR Turbo Back Review
Originally Posted by Genesis8
Get some kartboy hangers and you should be fine..
Originally Posted by jred321
i've tried kartboy hangers which made things worse because it pulled the exhaust up more because they don't have the same natural flex that the rubber ones do. but that natural flex is what prevents it from resting against the sway bar.
what i ended up doing is bending the hangers and using 3 of the kartboy hangers (the ones near the muffler). but now the muffler sits ever so slightly off center from the cutout in the rear bumper, which is what i assumed would happen if i played with the hangers. it's ok for now but eventually i'll either play with it more or just take it to a shop and have them redo the hangers
Originally Posted by atlvalet
Couple of things...
Be aware that the HKS Carbon/Ti muffler doesn't seem to be a full 3" muffler. It failed the Al coke can test. This is no fault of Ryan's, it is what it is.
Ryan told me they modified the muffler to make it a full 3", but I measured it and its not quite that big. Maybe slight bigger than 2.5" but definitely not 3"
No, all our of our exhaust components are a true 3".
If you opt for the HKS Carbon/TI muffler is has neckdown in the muffler to 2 7/8" I believe. There is nothing you can do about it, but if you want a true 3" just use the RnR N1 muffler or Magnaflow we offer.
From: Where you come to vacation and go home on probation! Vegas!
My only issue is my DP hitting my ACD and it rattles like crazy .. I wish there was a way to fix it with out wrapping it as the wrap jsut gets cut up and falls off over time.
Originally Posted by RnR Racing
Yes, if you have the older version downpipe then just heat wrap the downpipe in that section. It is an easy fix.
They By far have the Worst Customer Service though. I should have listened to everyone and went with AMS or BR racing, if you want the " JDM hottness" piece together your own exhuast.
