Adding some parts to the car on Friday..
Old Feb 9, 2006 | 04:39 PM
sway_'s Avatar
Sup all. Car currently has the 05 dynoflash ecu reflash (not custom tune), a perrin catback, and an HBC @ 22psi.
Friday i'm getting a new megan turbo manifold, o2 housing, downpipe, and test pipe.
I'm under the impression that I won't need a reflash, am I correct?
The car right now makes 262whp/262ftlb 12.3AFR, so i'm anxious to see what completing the exhaust system will do
Old Feb 9, 2006 | 04:42 PM
bluebanana23's Avatar
how did you get to 12.3? his flases are at 11.1! I wouldn't be boosting if I were you.
Old Feb 9, 2006 | 04:46 PM
Gruppe-S's Avatar
Wow, 12 afr is really lean...you might want to get it retune. Also, the car will run leaner when you free up the exhaust.
Thanks,
Tom
Old Feb 9, 2006 | 04:50 PM
Ultimate CC's Avatar
Yea I would suggest going and getting a dyno tune at the very least if you plan on adding those mods are are currently at 12.3 AFR
Old Feb 9, 2006 | 05:23 PM
Warrtalon's Avatar
I doubt your AFR is 12.3 above 3500rpm. Yes, you need a retune for all those new mods.
