Pennzoil Synchromesh=5th gear grind NO MORE!
Originally Posted by taenaive
yeah, I changed it and it was gone for a while. Then, it is coming back again slowly
Edit: ~2000 miles...
Originally Posted by use2vtec
Im glad its working for you. I never had a problem with the stock fluid either when it was cold. But when its in the low 40s high 30s and the engine is cold I have the hardest time with second gear
. Maybe the next time I do a fluid change I will swap over to the Pennzoil, afterall it is cheaper and can be found at any Autozone!!
Also you might want to look into some shifter base bushings/underhood bushings. They are pretty cheap and could prolong the life of your tranny.
. Maybe the next time I do a fluid change I will swap over to the Pennzoil, afterall it is cheaper and can be found at any Autozone!!Also you might want to look into some shifter base bushings/underhood bushings. They are pretty cheap and could prolong the life of your tranny.
i have problem shifting back gear when its cold///
i have to force it really hard to shift into back gear///im afraid i might break something.. i just have fresh syncromesh fluid in it.no difference/
anywant know what s going on?
pb91
Jun 8, 2011 02:44 PM
prowakeskater
Apr 22, 2011 10:28 AM
SlowCar
60
Dec 28, 2005 11:59 AM
