View Poll Results: How much oil do you add between oil changes?
one quart every 3750 miles
25
30.49%
two quarts every 3,750 miles
2.44%
more than two
2.44%
None, but I promise I check it
53
64.63%
Voters: 82. You may not vote on this poll
How much oil does your baby burn?
Old Feb 18, 2006 | 11:31 AM
hillbilly8R's Avatar
I better rephrase the question. How much oil does your evo burn? I was just bored and curious. I have 8,000 miles and add one quart every 3,750 (burns one between oil changes).
Old Feb 18, 2006 | 11:52 AM
nj1266's Avatar
Mine burns ZERO quarts. I put in 5 quarts and take out 5 quarts. I use the 5 gallon Mobil 1 container to measure what I take out from the engine. Did you break in your car using the Mitsubishi instructions? I remember reading in Car and Driver that it was essential to break in the Evo using Mitsu instructions, otherwise you will burn oil. Here is the money quote:
"For the first 600 miles, we treated the Evo like a cute baby lamb. That's because Mitsubishi tells us the break-in is a crucial time in an Evo's life. If you're kind for those first miles, you will be rewarded with quicker acceleration, and it will never burn oil, Mitsubishi claims."
http://www.caranddriver.com/article....rticle_id=9270
Your car should not burn oil in regular day to day driving. I have 5500 miles on mine and have done two oil changes w/o any loss of oil.
Old Feb 18, 2006 | 11:55 AM
bluebanana23's Avatar
22K and nope it doesn't burn oil. Time for new piston rings?
Old Feb 18, 2006 | 01:02 PM
johnturbotron's Avatar
2004 with 14,580 miles and uses no oil between changes and I bought it used with 8,500 miles on it.
Old Feb 18, 2006 | 01:08 PM
stryderlis's Avatar
I only burned oil during break in which I think is normal. But I've since been out of break in and have not burned oil since. I have done two oil changes since I bought the car. Currently have 5500 miles on the car. I changed at around 1500 because I noticed I was low on oil so I changed it. My second oil change I was still full to the top when I checked.
Old Feb 18, 2006 | 01:11 PM
ch47god's Avatar
no oil burn, sitting at 16k now.
Old Feb 18, 2006 | 01:20 PM
jrsimon27's Avatar
i burn 1quart of oil every 3000miles but if i push really hard my engine,but daily driving i mean normal driving no hitting redline i dont burn any oil at all and yes i did baby my car for the first 1250miles.
Old Feb 18, 2006 | 03:32 PM
I too treated her like a baby during break-in. I notice that my oil never moves on the stick unless I have been in the trubo (lup a mountain run). I have never let it drop below the "fill" mark. I just always keep it near the top marker and noticed it is "drinking" about 1 between oil changes. I noticed in the manual it's stated using oil is normal, guess that's there way out.
TarmacEVO707's Avatar
Doesn't burn any at all. 03 with 21k miles.
Old Feb 18, 2006 | 03:33 PM
GPTourer's Avatar
I burned a quart during break in, but haven't seen any usage since.
Old Feb 18, 2006 | 04:26 PM
gsrboi80's Avatar
Mine seems fine 35k
Old Feb 18, 2006 | 04:27 PM
mathgeek's Avatar
I usually burn a little between oil changes (half a quart every 5000 miles). I may be wrong, but it seems as though more oil is burned when I spend more time in boost. I went one oil change interval driving like a 95 year-old grandmother when gas was $49 a gallon a ways back. I never went above 4K RPM. I used no oil. Lately, though, I use a little bit. But then I seem to be indulging in more spirited driving.
Old Feb 18, 2006 | 04:45 PM
WrX Kila's Avatar
One quart every 3000 miles. I buy the six quart box at cosco. I put five quarts during oil change and before the next oil change the sixth quart is used up.
Old Feb 18, 2006 | 04:49 PM
PA-silver03evo's Avatar
None here. I usually check it before I drain it and its still right where it was when I first changed it.
jasonc32amg's Avatar
None
