Clutch install Question in a 2005 Evo?????
is the install for a clutch in a 2005 evo nearly the same as the 2003's??? i know they have the ACD but since i have an 03 im not familiar with if anything is different..... thanks!
https://www.evolutionm.net/forums/sh...5&page=2&pp=15
post #20 good luck and let us know how it goes.
round 2 has come and gone.... went on without a hitch.... 2005 evo has been defeated..... muhahahaha..... thats 2 clutches in 3 weeks
Bleeding ACD,
I know it has been discussed before but what would you guys recommend
1. do it yourself using some of the methods discussed
2. take it to the mitsu dealer.
3. or just dont do it (not recommended)
Thanks.
man the tob is soooooooo easy to get it to release i couldnt believe just how easy it was... basically put it in the open position put a screw driver up in there then move it to the close position and twist on the screw driver... pow... done sometimes you have to work the tob out the rest of the way but it isnt bad.....
and the method discussed is the one i used for bleeding the ACD it worked like a charm....But the other method to avoid bleeding caused me problems i couldnt find the leverage to break the bolt loose to do so.... its possible i guess to loosen the ACD line maybe move it a bit but to me it seemed easier to bleed the ACD it look me about 30 seconds to get rid of all the air...
help!!!!
