Dyno result by Türkish evo
Old Feb 24, 2006 | 04:59 AM
aps's Avatar
aps
Hi guys we finally did fine tune and got some numbers.You can see my mods in my signature.We use the Türkish 98 octane but ı think our 98 octane is equal to your 93 octane or 95 octane maybe.418hp@20,5psi and 490Nm
http://img60.imageshack.us/img60/1962/zantdyno9kt.jpg(you can see the dyno sheet in this link)
Old Feb 24, 2006 | 05:00 AM
aps's Avatar
aps
opss the link is not working sory.
Old Feb 24, 2006 | 05:20 AM
aps's Avatar
aps
Whp result is not configurated so this is not true result
Old Feb 24, 2006 | 05:21 AM
aps's Avatar
aps
Whp result is not configurated so this is not true result and ı think dyno is mustang dyno.
Old Feb 24, 2006 | 05:26 AM
joshd's Avatar
Yeah, I'm somewhat confused by that dyno sheet ... the way I'm reading it (probably wrong), the car put down 283.6whp and it's estimating that as 418.8 hp at the crank?
And did you really dyno in 5th gear or is that a typo on the sheet?!
off-topic edit: why is it that the rest of the World outside of the US seems to use estimated crank dyno numbers instead of actual power at the wheels?
Old Feb 24, 2006 | 05:34 AM
aps's Avatar
aps
no really 5th gear why? Yes ı explained the whp result, this is not configurated result but ı think 418hp=350awhp????
Old Feb 24, 2006 | 05:41 AM
joshd's Avatar
I think the usual rule of thumb is to use the gear that is closest to 1:1 ratio, which for our cars is 4th. But even then, most people here use 3rd as runs in 4th take longer and can heat soak the intercooler leading to worse results. I can't even imagine how long a 5th gear pull would take!
Not sure what you mean when you say the whp was not configured ... was the dyno not setup correctly? Dynos measure actual whp and then make some estimation of crank hp ...
Honestly I'm not sure what 418hp at the crank would equal at the wheels (and it's different on every dyno), which is why we generally use whp numbers, since we have no way of actually measuring bhp without taking the engine out and putting it on an engine dyno. Do you have a baseline result on that same dyno? That would help to see the gains from your mods.
Old Feb 24, 2006 | 05:51 AM
Phoenix_Master's Avatar
Congrats, did you install & tune the parts yourself or was it a shop there?
Old Feb 24, 2006 | 06:46 AM
aps's Avatar
aps
yes the dyno not setup correctly.No ı m not install myself we have alot of garage in here and the tuner is my close friend.We are going to record some video but ı dont know when.We have got serious car 650+hp (evos,m3,vette and supra) My aim is, ı want to represent Turkish mofied car's more detail to you.
Old Feb 24, 2006 | 06:55 AM
WRXEM's Avatar
Here is the link corrected guys
Old Feb 24, 2006 | 06:59 AM
aps's Avatar
aps
thanks dude
Old Feb 24, 2006 | 07:04 AM
WRXEM's Avatar
thanks dude
Anytime, nice numbers btw. I need to come over there and get some of that 98 oct
Old Feb 24, 2006 | 07:06 AM
aps's Avatar
aps
sure whenever you want.If you like ı will sent you
Old Feb 24, 2006 | 07:27 AM
rsboy's Avatar
Hey Ozant.. what's up man?
Nice numbers! :thumbup" Glad to see you car is making good power.
I see you got pretty much HKS everything.. why not change that K&N for the HKS intake?
Old Feb 24, 2006 | 07:33 AM
aps's Avatar
aps
heyyyy raynold dude everything is ok? Thank you for your good comment.Yess you right ı have to change K&N filtre and hks 2.5"dp
