high rpm's for 1/4 mile
Old Feb 24, 2006 | 10:55 PM
4WS Tuning's Avatar
to hit higher rpm's ex. 8k give or take....i need cams, valve springs and retainers...anything else? and what would i expect to rev with that...
the reason i ask is my mods list is almost complete and on the drag strip i would like to finish in 4th gear instead of having to make that shift into 5th and this seems like the solution...
thanks in advance!
Old Feb 25, 2006 | 12:10 AM
mikiblueeyes's Avatar
8000 will get you to about 120 or so. On the stock motor I wont recoment running much higher than 82-8400 tops. 8000 will be safe.
Goodluck
Old Feb 25, 2006 | 02:18 AM
4WS Tuning's Avatar
8000 with stock valvetrain or without? if with stock, how safe is that?
Old Feb 25, 2006 | 03:02 PM
4WS Tuning's Avatar
bump bump
Old Feb 25, 2006 | 03:04 PM
EvoDan2004's Avatar
im a sissy so i shift at redline. but this year after i get cams and valvetrain il be steping it up some. as for how safe. i say its safe to do till it brakes. lol
Old Feb 25, 2006 | 04:35 PM
Danny23's Avatar
you can go 7800 all day on the stock valve train
Old Feb 25, 2006 | 04:43 PM
housedj's Avatar
u will need ARP head bolts cuz the head begins to LIFT over 7850rpm. if you're gonna do cams, get valve springs, valve guides, retainers, lifters, ARP head bolts, & a Cometic head gasket. oh yeah, make sure all your internals are titanium. or you could just do what i'm doing & get a Cosworth built head. Also, Tomei is coming out with some 280 cams that will have 12.2 lift!!!!!!!!! i can't wait to put those in. the Tomei 280 11.8's already make the most power...
Old Feb 25, 2006 | 06:42 PM
anjapower's Avatar
head begins to lift over 7850?
Just get valve springs and retainers for the head. You should also think about better rods and rod bolts at that point.
There are a number of people taking the stock motor to 8k+ however.
Old Feb 25, 2006 | 06:45 PM
housedj's Avatar
Originally Posted by anjapower
head begins to lift over 7850? There are a number of people taking the stock motor to 8k+ however.
they don't realize that the car isn't making any power past 7500 even with a flash. i used to shift at 7800 until i took almost .4 of my 1/4 time by shifting earlier...
Old Feb 26, 2006 | 09:57 AM
TrinaBabe's Avatar
The head does not lift from RPMs Thats not very intelligent. The head lifts from high boost and power. Think about it... it is the top of the combustion chamber, more air you shove in there and bigger bang pushes harder against the head.
About what you need to spin it past 8k is nothing. I spin mine to around 8.5k quite often. Ive screwed up and spun it to 9.1k... stock everything with HKS 272/272 cams.
And about shifting earlier because your not making power that is not entirely true. Im not sure how much you know about how TQ works but the lower the gearing, the more TQ you make to the ground. It is like a pully system, you WILL accelerate faster in a lower gear even if you are technically making less power. On top of that you will hit higher in the next gear landing it in a better power band.
Old Feb 26, 2006 | 10:31 AM
sleet's Avatar
Many people on here do it.
Old Feb 26, 2006 | 10:42 AM
Warrtalon's Avatar
That's only because you have no clue what you're doing, yet you go around talking like you're an authority. It was retarded to ever shift at 7800 rpms. Everyone else knows not to do that, but this isn't even the point. People can make power up there with the right setup with the right cams. YOu had stock cams, so of course shifting up there was hurting you. This guy is asking about getting setup for high rpm power. Also, we have to rag it out really far in 4th gear at the drag strip, so it becomes very important to make safe and reliable power up there.
Btw, Miki, there's no way he gets near 120mph at 8000rpm. The IX 5spd has very short gearing. He might be at 115mph or so at that point...
Old Feb 26, 2006 | 11:36 AM
My bad, I didnt see it was Evo9.
Old Feb 26, 2006 | 01:29 PM
GTKage's Avatar
OMG how do u come up with those stuff??? the head lift over 7850rpm ? lmao, stock head is good to be reved up to 8K rpm. Please before u say anything on this forum again please be sure to write something smart, all u have been doin so far is make yourslef look like a fool
Old Mar 8, 2006 | 05:23 PM
4WS Tuning's Avatar
i just want to be in the 11's consistently...and with out being able to rev to 8000...thats going to be hard.... at 7600 im at 113 thats a low allllllllllllllllllllllllllllllllllllmost an 11.... i shift when i feel the power dying off.not at max rpm be4 the car blows up...its not a v8...
