Turboxs Downpipe with o2 bung??
Old Feb 27, 2006 | 10:43 PM
03redtype-s's Avatar
Hey guys well ig ot my downpipe in today and its got a spot for an o2 where it meets up with my test pipe. I believe this is for a wideband o2 since the first o2 is in the o2 housing right? so my question is do i just put a bolt in there so it doesnt leak exhaust out of it? And if so what size do i use. Thanks for the replys
Matt
Old Feb 27, 2006 | 10:45 PM
bbbwrx's Avatar
Yes it is for the a aftermarket wide band. There is another o2 sensor closer to the rear of the car and one in the o2 housing. You should have gotten a plug with all your hardware. Small short bolt. I forget the size but i am sure somehere knows the size. Thanks.
Ben
Old Feb 27, 2006 | 10:55 PM
yeah i didnt get any hardware with it so im assuming that i will use my factory bolts and such but i just need to get a bolt for that bung. I can probably get one from orielys or autozone cant i?
Old Feb 28, 2006 | 04:31 AM
Drifto's Avatar
You cannot install it without the hardware pack that comes with it. This includes gaskets, new bolts w/ springs for the o2, bolt to seal the o2 bund, and a large doughnut gasket. Get on the phone or go back to whereever you got it and get your hardware.
Old Feb 28, 2006 | 04:35 AM
kmcconn9's Avatar
/\ correct. Call turbxs and tell them you didnt get the hardware kit for their downpipe and you will be set. It has everything that you will need to install the downpipe, without it the downpipe is useless.
The hardware kit costs 35.00...
Old Feb 28, 2006 | 08:30 AM
basically what i need woul dbe the gasket right? the one that where it bolts up to the o2 housing right?
Old Feb 28, 2006 | 06:39 PM
dcvolki's Avatar
u need the hardware kit to install the dp
the hardware kit comes with the
large doughnut gasket , bolts/springs for the o2 housing , bolt to seal the o2 bund , spacers for the lower bar
Old Mar 2, 2006 | 09:10 AM
guys thanks for the help called up turboxs and they are sending me the hardware kit since i didnt recieve it thanks again.
03redtype-s
May 29, 2009 11:02 PM
03redtype-s
20
Nov 18, 2008 01:43 AM
03redtype-s
13
Sep 9, 2008 07:19 PM
03redtype-s
Jul 7, 2008 05:08 AM
03redtype-s
Feb 9, 2006 05:16 PM
