Are the hks 272/272 cams worth it?
Yes youll need it for an upgraded turbo. Its hard to really max out the stock injectors on the stock turbo. Im doing it but my numbers are higher than most.
I was at 100% IDC on my 378whp run on pump gas.
I've been told that using 272I/272E cams gives you a rough idle, the guy i talked to at AMS recomended going with 264I/272E without adjustable cam gears, do you think i would like 272I/272E better though? should i get adjustable cam gears, or no adjustable cams gears?
I wouldn't spend the money on HKS. Comp cams are just as good if not better and about $250 cheaper. The cams and a fuel pump are all you need. I've got cam gears on Comp 272's. You will hear different opinions on if they are worth it or not. They are the single best mod I have done. I'm like you I don't go to the track often but, enjoy working on my car. So, I keep going.
"I've got cam gears on Comp 272's. You will hear different opinions on if they are worth it or not. They are the single best mod I have done."
What was the single best mod, the cams or cam gears?
I am not sure why everyone recommends spending $600+ on cams which typically only yields a 30-40 hp increase in power (if that). Doesn't it make more sense to just spend the money getting your car tuned to run more boost? (bigger injectors/fuel pump/flash/boost controler)?
Yeah but many evo owners opt for a cam install as one of their first mods, which I think is incredibly stupid. Cams aren't a good mod for the money spent. There are many DSM owners running 600-700 hp cars on a stock head with stock cams.
I have a 2005 Evo VIII, so far i have intake, AMS TBE, and AMS lower intercooler pipe. I was planing on going to AMS this spring to have my car tuned, and was wondering if getting the HKS 272/272 cams W/ cam gears, Fuel pump and injectors, and arp head studs was really worth it? Im asking because it will take me a few months to save up the money, and i dont plan on racing the car. I've just become trapped in the EVO modding. I love the car, and love the power, but cant decide if these things will be worth it. Also, I dont plan on upgrading the turbo. I just want as much reliable power as i can get without going into debt.
...Also, if anyone has any better ideas im open for suggestions.
Thanks...
Thanks...
PTE 680cc INJECTORS $220 shipped anywhere used under 500 miles !
Not to mention where cams make the power. I mean lets face it the bottom end power is pretty much non existant so, you might as well be making more power in the mid-range and top end where you can use the power and the factory turbo is running out of breath.
