Data on various MY Blown Engines
Old Nov 8, 2008 | 09:16 AM
  #121
broddey's Avatar
Model year: '06
Mods: HKS RS Intake, 280's, FP, Self Tune 93oct, 23psi, TBE, TRE 5speed+Rear Diff
Miles: 28k
Conditions: Track Day @ Sebring, chasing some track prepped 911 Turbos on a hot day, drafted for 5 laps and over-temped radiator then spit a rod out front of block and cap out the back (2 holes in block, just to make sure it was dead )
Pics: On The Way
Race/Track History: 3 roadcourse weekends, 6 autox, daily flogging.
Contributing Factors: #3 rod separated in two. No over-revs that I know of. Hit the raised rev limiter a few times @ 7800. Oil was changed after every trackday and everymonth when not being tracked.
WATCH YOUR WATER TEMP!!!!!
Old Nov 8, 2008 | 02:42 PM
  #122
C6C6CH3vo's Avatar
I guess the evo is not designed for the track if pushing more power. You basically exceed the engines thermal limit. The design is probably just pushing it stock. A 911 turbo can do that for hours
Old Nov 9, 2008 | 09:12 PM
  #123
chad99evo's Avatar
i disagree with your opinion/post in certain areas. preferable the "pushing it stock" part
theres a member of motorsport ranch kelly and i know that bought a stock evo, put hoosiers and basic bolt ons on it, and they have over 8000 pure track miles on the car and are still running it with no problems. this car isnt even daily driven...100% track time minues engine break in procedure.
Jim another member of our evo club has 98k miles and tracks his car once a month.
kelly is a member of MSR also, he has 90k miles and tracks his car twice a month.
there are more, but i dont need to prove a point or start an argument. the evo in my opinion is a great and reliable track car from the factory. its all in how we(the evo owners) choose to screw it up for ourselves, for instance, huge turbos and over-revving etc.
Old Dec 9, 2008 | 01:33 PM
  #124
mega-z's Avatar
Bent rod cylinder 3, over boosting on a cold night, from a busted hose running from the waste gate!
Make sure u check ur hoses everyday people. It will save u time and money.
Old Dec 9, 2008 | 07:31 PM
  #125
chad99evo's Avatar
i have a set of stock evo 9 pistons and rods. all you need is bearings.
Old Feb 3, 2009 | 09:27 AM
  #126
zeus1's Avatar
Model year: '05
Mods: see sig
Miles: 75k
Conditions: cruising on the higway 75mph 5 degree F out. blew the rod from cylinder 1 out the bottom of the block: rod from cylinder 1 broke in half near the crank.
Pics: non so far
Race/Track History: never tracked or raced
Old Apr 15, 2009 | 10:43 AM
  #127
Daryl Nilsen's Avatar
Did you blow a built 2.0? or is that whats you have now after the blown motor?
Old Apr 20, 2009 | 12:05 PM
  #128
zeus1's Avatar
i blew the stocker..
Old Apr 27, 2009 | 06:58 PM
  #129
detroit pistins's Avatar
great info in this thread.
Old Apr 27, 2009 | 07:25 PM
  #130
laramie_05MR's Avatar
Model year: 2005 MR
Mods: see sig
Miles: 73,xxx
Conditions: Texas Mile-airport runway
Pics: none yet
Race/Track History: a few quarter/eighth mile passes(this is my only car)
Contributing Factors: failed spark plug on number 4 melted the piston
Old May 8, 2009 | 11:19 AM
  #131
fanbelted's Avatar
I noticed there are not a lot of IX's in this thread, and the ones that are were flogged pretty hard and heavily modded. Does that mean the IX had a lot of weak spots designed out, or just not as many people owning one?
Old May 8, 2009 | 03:44 PM
  #132
blackdemon's Avatar
+1
Old May 8, 2009 | 06:20 PM
  #133
C6C6CH3vo's Avatar
The IX has higher thermal limitations, the VIII's are older were put through more suffering from bad tune back when tuning was in it's infancy stages
Old May 18, 2009 | 10:51 AM
  #134
C6C6CH3vo's Avatar
Originally Posted by dzikumr9
i blow my engine 40 miles after was tune
40 miles after it was tuned? Who tuned it?
Old May 18, 2009 | 10:54 AM
  #135
fanbelted's Avatar
Man that is a bummer. Sounds like a bad tune! If you are anywhere near the Portland/Vancouver area, I'd recommend you go to English Racing. They did a fantastic job on my Evo IX MR. It's putting down 350whp on the dyno, at 25psi. I've been driving it for about 4 weeks and the engine knock light has only lit up twice, briefly.
