Blown head gasket..
Old Mar 27, 2006 | 07:48 PM
  #31
houdni's Avatar
i usually find the best gaskets are the stock ones.
Old Mar 28, 2006 | 06:36 AM
  #32
Mr Evolution's Avatar
Stock is great, but since you have to replace a head gasket might as well and get ARP head studs too.
Old Mar 28, 2006 | 02:32 PM
  #33
IEXCELR8's Avatar
The car has them already. It was a freshly built 2.3 block with rods/rings, pistons,springs,retainers. Was broken in on the wastegate psi for 500 miles then 20psi on pump for about another 400-500miles. The motor has 1k roughly on it.
Mike
Old Mar 28, 2006 | 02:40 PM
  #34
jbergmeier's Avatar
seems kinda odd for ARPs to let that happend, inless they were not torqued to spec (85ftlbs)
Old Apr 3, 2006 | 06:17 PM
  #35
IEXCELR8's Avatar
Well checked headstuds and they were dead nuts, so a new gasket it will be.
Old Apr 9, 2006 | 12:46 AM
  #36
IEXCELR8's Avatar
Well took 2.5 hours to get it all apart. Did a leak down test and cyl 1 was leeking into cyl #2. So I got a new stock gasket and it is the same as the one I pulled out??. Hopefully this will not blow when I put it all back together this week. I am having the head checked for warpage and cracks from a machine shop before I install the new gasket. I actually picked up 2 so I have a spare just incase I ever need another. Seemed hard to get from dealers and I drove 1 hour away.I will post up picks so you can see how little use the motor has had.Also my T-belt seemed pretty lose to me and my buddy.
Old Apr 9, 2006 | 01:50 AM
  #37
trinydex's Avatar
so did the gasket you took out have an area where it looked like it leaked from?
Old Apr 9, 2006 | 10:12 AM
  #38
IEXCELR8's Avatar
Yup, not so noticeable though. I have a feeling it had just went and I caught it without putting very many miles on it.Also has a scratch on the head as if the headstud hit the head. Iam going to have it checked for a crack and straitness on Monday.
