Lean Bank 1 P 0171??
Old Mar 13, 2006 | 09:24 AM
smokey's Avatar
I have done a little research on this and the answers I see seem to be the same but I want some people's opinion.
Every since I installed my 720cc injetors I have gotten this SES of Lean bank 1. Now I tried switch O2 sensors and that didn't work and my A/F ratio is about an 11.7:1. I am pretty sure it is my injectors but why would you get a lean bank 1 code if you are still running rich?
People have said it might be lean in the first couple thousand RPM's. So why wouldn't it be a problem through all RPM's??
Any suggestions or help would be greatly appreciated. I am going to switch back to stock injectors and have the 720's replaced under warranty...but I want people's opinions and thoughts as to why injectors would lean out in the very early rpm's and not in the later rpm's.
Thanks
Old Mar 13, 2006 | 09:30 AM
Nesiop's Avatar
I get the same thing with 1k's, IDCs are at like 55% or so WOT throughout RPMS, and I run an 10.7-11.5 AF and still get mine.
Old Mar 13, 2006 | 11:05 AM
smokey's Avatar
WHat's the IDC's???
Old Mar 13, 2006 | 01:26 PM
Nesiop's Avatar
Injector Duty Cycle.
Old Mar 13, 2006 | 03:42 PM
smokey's Avatar
Thank you. did you ever get the code fixed? Where you worried about running lean and hurting the engine??
Old Mar 13, 2006 | 07:27 PM
KevOVIII's Avatar
Who makes the injectors? I used to get the same issue while cruising or during idle but I added fuel from 2250 to 3250 and at idle. No more code now.
Old Mar 13, 2006 | 07:36 PM
Nesiop's Avatar
I run AMS injectors. Which are Precision.
I still get the code but at idle my short terms are still messed so I need to add more fuel.
Kaezox
Jun 10, 2017 01:34 PM
richardjh
Jun 18, 2011 10:16 AM
cij911
Mar 26, 2009 08:17 PM
spoonerr
Oct 11, 2007 11:38 AM
