what a/r for gt35r with my mods
Old Mar 19, 2006 | 05:18 PM
forum04pl's Avatar
im looking at turbos still and have everything needed to bolt on a t3 turbo. i was wondering what a/r's and housings were recommended for a car with my mods (check sig)? also i have heard that the 5bolt housing has a more restricted flow than the 4. is this true? because i already have a 5bolt o2 housing but if it is loosing power then i will probably swap it out. also what size is the exhaust exit on a 35r, 2.5" or 3"? thanks for any help
Old Mar 19, 2006 | 08:17 PM
forum04pl's Avatar
this many views and no suggestions?
Old Mar 19, 2006 | 08:37 PM
evolved4g63's Avatar
You can get a 3in or 2.5in exit for the 4 bolt housing. You prolly want a .63 turbine housing. And a ported "s" cover for the comp. I have a theory that you will gain power with the 4 bolt housings. But "possibly" less lag with the 5 bolt. In theory.
Old Mar 19, 2006 | 08:39 PM
forum04pl's Avatar
hmm alright, why exactly do you reccomend the .63 and the ported s cover?
Old Mar 19, 2006 | 08:43 PM
You got it. If you go with a larger hot side like .82 it will be laggier. And if you use the regular "e" comp cover, you will see surging problems.
Old Mar 19, 2006 | 08:45 PM
BTW, as of now i'm using the 5 bolt. I may try the 3in. 4 bolt in the future and see what happens.
Old Mar 19, 2006 | 08:53 PM
forum04pl's Avatar
thanks for the tip on the e cover, what are your numbers like with the 5 bolt?
Old Mar 19, 2006 | 08:55 PM
A conservative tune, with a mix of 93 and 116 was 421 on a mustang dyno.
Old Mar 19, 2006 | 08:56 PM
Do you have the equal length mani from rnr?
Old Mar 19, 2006 | 08:57 PM
forum04pl's Avatar
yeah i have the equal length, right now im debating if i want to try the 4 or 5 bolt becuase i already have a 5 bolt o2 housing. do you think the gains will be worth the upgrade?
Old Mar 19, 2006 | 08:58 PM
forum04pl's Avatar
great numbers on pump and on that dyno btw
Old Mar 19, 2006 | 08:59 PM
Im guessing, but 30-40. I really have no clue. But when you look at the 5 bolt it does look very restrictive compared to a 3in. hole.
Old Mar 19, 2006 | 09:03 PM
forum04pl's Avatar
wow, definatly going with the 4 then. thanks for all the help. any reccomendations where to get the turbo from? ive been looking around and found a few good sites for garrett turbos.
Old Mar 19, 2006 | 09:12 PM
What kind of prices for the garrett? PTE is always a good choice, basically the same. The ported covers are different. The PTE may be cheaper. But you need to find a distributor. I lucked out on that. I went from a 50trim to the 35r as well. Found a used one for 750, with the e cover. Then had dsmotorsport send it to pte for the ported cover. The backing plates arent the same, and they also rebalanced the wheel.
Old Mar 19, 2006 | 09:15 PM
forum04pl's Avatar
the best i have found on the garrett is 1250, then i would need to get the flange and fab up a o2 housing and run oil and water lines. yeah i talked to someone i know about the pte 35r and they said that they probably couldnt get it for a little while.
