Stupid Oil Question
Old Mar 22, 2006 | 10:00 AM
evopower1021's Avatar
Originally Posted by DaWorstPlaya
Actually 0,5 and 10 are the weight of the oil and 30 is the viscosity index, with that, it shouldn't be a problem running 5W-30 Mobil 1. Temperature and pressure affect the weight and viscosity of the oil and the oil we use maintains its viscocity up to certain temperature and pressure ranges. In colder weather the oil gets denser and heavier per volume, thus you want to move to a lighter weight oil.
my explanation meant pretty much the same thing except i didn't use the word viscosity.
Old Mar 22, 2006 | 10:05 AM
TxEvo8's Avatar
You are asking people who are both not experts and are making assumptions, why not just take it back and get the oil that the manual suggests? It seems easy enough.
Old Mar 22, 2006 | 10:52 AM
M3this's Avatar
From: Where you come to vacation and go home on probation! Vegas!
Yea but I cant find the reciept and I threw away the case box
Old Mar 22, 2006 | 03:07 PM
Aby@MIL.SPEC's Avatar
I wouldnt worry too much about this, the difference between 5w30 & 10w30 isnt that great. As long as your running mobil 1, you'll be fine.
If your so concerned, just change the oil again & that way you'll have a piece of mind & you'll sleep better.
Old Mar 22, 2006 | 04:11 PM
C6C6CH3vo's Avatar
I heared of people getting noise on top with the 5W
