greddy ebc
Old Mar 25, 2006 | 04:26 PM
Mr. Boost's Avatar
greddy ebc
when installing the greddy ebc with an extrenal wastegate like tial, how do the lines off the ebc pressure sensor go to the 2 ports on the wastegate?
Old Mar 26, 2006 | 09:22 AM
JonEvo's Avatar
this is how mine is set up with the tial wastegate
Old Mar 26, 2006 | 10:37 AM
Mr. Boost's Avatar
i didn't see a place for a vacum line to go to on the turbo, could mine possible not have one?
Old Mar 26, 2006 | 11:43 AM
jj_008's Avatar
Usually there is a fitting tapped into the compressor housing or on the LICP. If you don't have either of those then you could tap off the BOV line.
Old Mar 26, 2006 | 12:03 PM
w_tomas's Avatar
If you have the turbotrix turbo kit you don't have a vac fitting on the compressor housing. You will need to tap one in it or tap a vac fitting on the licp.
Old Mar 26, 2006 | 06:51 PM
Mr. Boost's Avatar
ok cool thanks for the help gonna use the bov line
Old Mar 28, 2006 | 08:59 AM
Mr. Boost's Avatar
http://www.atpturbo.com/Merchant2/me...egory_Code=BCS THIS LOOKS LIKE IT COULD WORK PRETTY GOOD.
Old Mar 28, 2006 | 09:07 AM
jj_008's Avatar
I had the quick tap on my old turbo kit and it worked great.
Old Mar 28, 2006 | 12:45 PM
LA EVO 8's Avatar
i have the ATP tap kit fitted onto the lower IC pipe and it works great, no leaks...
SkyNight
Jun 24, 2010 07:29 AM
blanknotice
Oct 9, 2009 11:47 AM
SOEX
Northwest Region
Aug 9, 2009 02:12 AM
krazy srt4
For Sale - Part Outs
18
Dec 11, 2007 11:38 PM
AfireINSIDE
Feb 17, 2007 05:35 PM
