MBC problem
Old Mar 27, 2006 | 03:13 PM
Turbo-Evo2346's Avatar
MBC problem
ok so unless my boost gauge is wrong which im pretty sure its not....my car is only running 17PSI and i tried to raise the boost with my hallman MBC but i turned it as far as it goes and nothing happened. I checked all the lines and everything is perfect. Anybody have any idea what this could be?
Old Mar 27, 2006 | 05:49 PM
Warrtalon's Avatar
Are you sure you tightened it all the way to the maximum possible? If so, then perhaps it has a weaker spring, or the installation is improper. There are many troubleshooting steps here, but here's some quick questions?
- Did you just install the Hallman recently?
- Has it ever given you more than 17psi?
- At minimum, does it give you 11psi?
- How did you install it?
- Did you reuse any of the stock vaccuum hoses?
Old Mar 27, 2006 | 06:15 PM
BSREVOLUTION's Avatar
i just had a problem with my hallman. my hallman would not hold boost. so i took it apart and replaced the o-rings. now it works as before. i hope your problem is an easy fix too.
