View Poll Results: How often do you replace your spark plugs?
every ~3k miles
18.75%
every ~5k miles
25.00%
every ~10k miles
15.63%
every 15k+ miles
3.13%
still stock - post your mileage
12
37.50%
Voters: 32. You may not vote on this poll
spark plugs
Old Mar 31, 2006 | 07:31 AM
jxs1984's Avatar
spark plugs
Post your info below.
Miles: ?
Spark Plugs: ?
Mods: ?
Old Mar 31, 2006 | 07:35 AM
cfdfireman1's Avatar
When they need to be replaced.
I change mine when they need to be replaced.
Anarchy99's Avatar
It's hard to say, it's all up to the plugs when there bad they are bad. I can tell you i use ether BPR7ES or BPR8ES with a .025 Gap and 22psi and lots of mods.
Old Mar 31, 2006 | 07:42 AM
jxs1984's Avatar
im still on stock plugs which have 17k miles on it. do i need to get them replaced when im doing 23psi with dynoflash @ 300whp?
Old Mar 31, 2006 | 07:43 AM
djscoto's Avatar
still stock - 6000 miles Evo IX daily driver.
Old Mar 31, 2006 | 07:49 AM
nixx's Avatar
20k mi, 05 EVO, original plugs..
Old Mar 31, 2006 | 08:10 AM
sleet's Avatar
32,000 miles. I think i'm on my 3rd set of plugs or so, BPR7ES FTW.
Old Mar 31, 2006 | 08:16 AM
Anarchy99's Avatar
You will have to use your best guess if you need new plugs or not but at $7.00 for a set of BPR7ES it's not much to pay just put some new plugs in it's only $7.00.
Old Mar 31, 2006 | 08:24 AM
Soon2BEVO's Avatar
Im averaging about 5-6k miles on BR8ES plugs. Gap is set to .026-028.
Old Mar 31, 2006 | 08:26 AM
fsugatorbait's Avatar
I change them every 5k with the motor oil. BPU. BR8ES gapped to .026.
Old Mar 31, 2006 | 08:50 AM
fbomb's Avatar
same here every 5k...
Old Mar 31, 2006 | 09:04 AM
Ev0ikon's Avatar
I change them out when I start to get miss fire :} Stock Iridium first 20K miles, then NGK BPR8ES for the next 10K miles with lotsa boost and Methanol (spike to 30 PSI and let it fall), I am on my second set of BPR8ES.
From now I I think I'll change them every 3 oilchange ~ 9K miles.
Old Mar 31, 2006 | 09:13 AM
hawjdude's Avatar
I change my every 5k. Using BR7ES right now but going to use BR8ES.
Old Mar 31, 2006 | 10:32 AM
EVOONYOASS's Avatar
I have to change mine out every 1,500 miles or whenever it starts to misfire. Sometimes it does it after about 1000 miles. BR7ES gapped to .025 using HKS DLI 2 and Magnacore 8.5 wires.
I go through plugs very quickly for some reason.
Old Mar 31, 2006 | 10:36 AM
Erik@MIL.SPEC's Avatar
That's not normal, is it? THere has to be something not exactly right somewhere.
