To GT35R or FP3065 ???? choices, decisions....
A GT35R on a DynoJet can make anywhere between 420WHP and close to 450WHP. On race gas on the stock bottom end Sean Ivey just tuned 550WHP. On a built bottome end 650WHP is achieveable. Go for the 35R over the GT3076R, believe me.
EVODave made 558awhp on the stock block with GT35R and pump/meth as well. That turbo is hard to beat if you plan on running alcohol/meth injection.
Originally Posted by Soon2BEVO
Actually S. Ivey made 550whp with 93 pump with methanol on the GT35R (Shearer's kit). The dyno realistically was 530whp pretty strong, if you look at the dyno it had a bump at the end, but nonetheless, incredible power for that setup.
Thanks Tom, that's what I hope to accomplish as well but only with a flash from Al.
theres a guy over running the Buschur/Fp3065 combo on a built motor with ported head, buchur intake mani, buschur TB, making 470whp on a dynojet at a little over 30 psi. The car has AEM in it and is tuned to the max. It just wont make any more power
J-Rod was close to that on BR's MD wasen't he? He ran a 11.0x @128ish, that seems like a whole lot more power then 470whp on a DJ.
3065
TurboTrix gave me a great deal on the AEM and install.They also made me custom intercooler pipes that are also beautiful.I had noticed that the clamp on the turbo outlet was leaking and I had realigned and tightned everything good when I installed the new race front mount.
David did an amazing job on my car and I'm very happy,he was also pointing out how much more torque I was making with the revolver's over Jarrod's car.
^ So........ it made a hell of a lot more power on pump and race gas-what does that mean? What power/tq did it make at what psi on what fuel? If you did a high/low boost or pump/race gas tune what did it make?
Scorke
Scorke
Those numbers 480 whp was on c16 on a dynojet. Im just wondering what it makes now. With that boost leak fixed the car is seeing afr's of 12.4 on pump. That needs to be addressed, but Im just wondering if this leak was presents when it was originally dynoe'd. But regardless the car makes a ton more power now.
