Why change pistons?
Why change pistons?
Hello people,
I've got some questions for engine gurus. I apologise in advance if the answers are rather obvious. Also, I do not intend this to be a 'if it's so good, why doesn't mitsu do it' or 'stock is all you'll ever need' threads.
For sometime I've seen people upgrading cylinders and rods etc. in their engines. In fact, when I used to race Civics, I too had Jun/Toda pistions, rods and crank shafts. As I was not really responsible for tuning the car when it came to engines, I didn't really know what they were for, except that I could rev higher, quicker and a little more safely.
So here are my questions:
Thanks in advance.
- At which point (in terms of boost, compression or hp) do the stock pistons/rods/crankshaft become inadequate?
- Are there any gains to be expected from just changing pistons and rods? Obviously, lighter moving parts are better, but any figures?
- Are there any other advantages, other than more power (if that) to be had from aftermarket pistons, rods etc.?
- This might be a little stupid - how does the piston design affect compression ratio?
- Why does the Cosworth website show two piston sizes? Is it common to make your engine a larger bore?
Thanks in advance.
