Why should anyone upgrade turbos?
33-34psi on pump gas/no meth on a GT35r and putting down 600whp? Come on, we know better...
Originally Posted by nrcooled
Reading compressor maps has never been my strong-point. I guess it's time to learn.
l8r)
Originally Posted by blkAMSevo8
no reason to lie, ill have some charts to prove it if you really want.
If you can prove with those charts that it's only 93oct with no meth and no other power-adders, sure. How is it possible to run 33-34psi on 93oct with no knock suppression?
Ok obviously he isnt running 34 psi on 93 octane. We all know this. So why are you trying to argue with him.
nrcooled. The stock turbo with your 2.3 liter will run out of steam short of your 7500 rpm redline. If you want to keep stock like spool, maybe buschur's 20g is your answer. Other then that Ted B has your answer.
Originally Posted by hondafan
running 20 psi on pump on a stock turbo will not top the horsepower number of a 35R at 20 psi on pump fuel. so more hp at the same boost level on pump. have you seen how much boost is required on an 8 to make 375 whp? now, how much boost on an 8 with a 35R? both on pump fuel. to make 375 on pump, stock turbo, you'll probrably need alky.
then you are actually flowing more air at 20 than stock.
All I got to say is, yes that power can be seen with that set-up running C16 OR meth, alky injection mixture b.s. however you want to say it w/ pump, but on pump alone.......... monkeys would fly out if my a$$ first !!!
Originally Posted by 13-0
And what calculations did you do to determine that? Please share.......
As usual this entire thread has been side-tracked.
I, for one, would like to hear more opinions on stock turbo vs. upgraded turbo. Especially considering how much power the IX seems to be making on its stock snail.
l8r)
