O2 sensor
Old Apr 13, 2006 | 12:43 PM
oldscholevo's Avatar
O2 sensor
Dose anyone know how to change the O2 sensor on the Evo9. The one on the cat? It's doesn't look like there is a connector on the wire? what the hell?
Old Apr 13, 2006 | 12:52 PM
SilverNine's Avatar
bump
Old Apr 13, 2006 | 12:56 PM
midwestmonster's Avatar
I know on the VIIIs it is under the passenger front seat. It's probably the same on the IX.
Old Apr 13, 2006 | 12:57 PM
Doogie Howser's Avatar
02 sensor socket or 22 mm open end wrench will take it off...
The wire is pretty long, and is connected under the passenger/console area...
Old Apr 13, 2006 | 01:00 PM
4TUN8's Avatar
22mm? I thought it was 18mm.....you sure it's not 18mm?
Old Apr 13, 2006 | 01:04 PM
eh I used an 02 sensor socket so can't recall but I am pretty sure its 22mm
Here is the evomoto link which claims 22 mm :
http://evomoto.com/tech_info.php?tPa...91b7b4b26d4eaf
Old Apr 13, 2006 | 01:16 PM
any picture on this forum?? would love to see how it is done and how to take the connector and wire out of the car.
Old Apr 13, 2006 | 01:19 PM
Well you don't need to take the connector out of the car, you just need to make sure that when you remove the 02 sensor that the wires do not get excessively tangled and be sure keep track of the number of turns you made with the wrench or socket, so when you put it back you won't under/over torque the sensor.
What exactly are you trying to install? A test pipe?
Old Apr 13, 2006 | 01:28 PM
no no, just incase the O2 sensor is not good and needs to be replace. So I will know how to do it myself. You know don't want those Mitsu mech to mess around my car.
Old Apr 13, 2006 | 05:00 PM
4TUN8's Avatar
damn I don't know why I thought it was 18mm.
Old Apr 16, 2006 | 10:34 AM
cdavy's Avatar
Registered User
Just did the O2 sensor on the turbo housing and it was 22mm.
