Rocker arm came off the lash adjuster
Old Apr 17, 2006 | 05:31 PM
althemean's Avatar
Well....finally after cracking open the valve cover one of the problems with the motor became apparent. The rocker arm on the #4 cylinder on the intake side is off of the lash adjuster.
There is still metal inside the cylinder so I still need to remove the head to find out if there is any internal damage.
Sorry the pics are so blurry but I cant do high res on this sight and the auto focus on my camera sucks.
Here is a link to the original thread about what happened the day the motor quit.
https://www.evolutionm.net/forums/sh...d.php?t=193132
Attached Thumbnails Rocker arm came off the lash adjuster-intake-cam-1-2-.jpg   Rocker arm came off the lash adjuster-intake-cam-1.jpg   Rocker arm came off the lash adjuster-intake-cam-2.jpg
Old Apr 17, 2006 | 05:36 PM
johnny's Avatar
Registered User
Dam bro Im sorry to hear that. Wish you the best.
Old Apr 17, 2006 | 09:03 PM
althemean's Avatar
Does any one think detonation could have caused this? The plugs showed signs of detonation for sure. But what led to this? The Rev limit was set at 7600 RPM. I bounced it off the rev limiter a few times in the lower gears. While racing and what not...you guys know how fast the car can rev.....but thats about it.
Old Apr 18, 2006 | 07:57 AM
mike 99gsx's Avatar
What cams and valve springs are you running?
Old Apr 18, 2006 | 08:06 AM
ExViTermini's Avatar
if you look at the picture you can tell its all stock.
Old Apr 18, 2006 | 08:18 AM
mike 99gsx's Avatar
If you can ID that by those blurry pictures then your eyes are better than mine
Old Apr 18, 2006 | 08:20 AM
Event-Horizon's Avatar
This was probably due to the engine floating valves when you bounced off the rev limit. The metel in the cylinders may be from the valves striking the pistons.
Tw3NTy0n3
May 21, 2016 11:24 PM
Myszkewicz
04-06 Lancer Ralliart How To Requests / Questions / Tips
136
Oct 11, 2013 02:04 PM
Slava
Feb 2, 2008 07:03 AM
Joho22
Jun 15, 2007 11:56 AM
KK
Jan 28, 2005 11:49 AM
