loud booming clunk on fast 1-2 shift
Old Apr 20, 2006 | 07:03 AM
texrex2002's Avatar
so whats the loud noise from the back of the car on a fast 1-2 shift?
the rear diff bouncing against something?
Old Apr 20, 2006 | 07:11 AM
Jasil's Avatar
I get them on fast shift using the clutch and it's worse if I'm powershifting sorda annoying! None of my previous DSM's ever did this, but it seems to be a common but normal issue.
Old Apr 20, 2006 | 07:17 AM
WRXEM's Avatar
happened on the 03 i test drove years ago, but does not happen on my g/f's 03
Old Apr 20, 2006 | 07:21 AM
Ev0ikon's Avatar
It's the loose mounts that hold the rear diff.
Spooldyou's Avatar
hhmm, my car starting doing this every once and than at the track. Kinda sounds like a belhousing? `
Old Apr 20, 2006 | 07:24 AM
GHEvo8's Avatar
my car did it from the day i broke it in till now, i dont belive its anything to worry about unless it starts to get louder and louder
VenomEVO8's Avatar
Y I have a clunk also.. but sounds more like its the tranny... Ill have to check this out now
Old Apr 20, 2006 | 07:31 AM
Wheelhaus's Avatar
Many Subaru's do this also on some hard shifts, my '04 STi did. My IX MR has done it as well. In both cases I believe it's (as stated above) the rear diff mounts clunking because they're soft. Replacing bushings is popular amongst the Subaru crowd, but I haven't come across anything for the Evo (haven't really been looking, either).
Old Apr 20, 2006 | 07:46 AM
dan628's Avatar
Mine does that too, I wonder if there's any kinda poly bushings that could be installed or a brace or something???
Old Apr 20, 2006 | 07:49 AM
Rich_1's Avatar
This Happens when you power shift.... you need to slip the clutch into 2nd when you mash....
Old Apr 20, 2006 | 09:33 AM
dayf's Avatar
Didn't you have a WRX? Mine did the exact same thing on a quick 1-2 shift. Try not to side step the clutch is all I can say.
Old Apr 20, 2006 | 09:41 AM
KOEvo's Avatar
I love the noise, it tells me i'm shifting fast enough .
Old Apr 20, 2006 | 09:43 AM
Ev0ikon's Avatar
Trust me on this. It's just the loose/soft rear diff mounts. You can buy harder mounts for it, but then do you want the mount to take the shock or the Diff itself?.
On my car if I shift too fast it will sound and FEEL like a sledge hammer hitting your back.
Old Apr 20, 2006 | 10:05 AM
GPTourer's Avatar
Mine does it too. I just started letting the clutch out slower and it won't.
Old Apr 20, 2006 | 10:08 AM
Tristar's Avatar
