driving without a cam cover?
Old Apr 24, 2006 | 09:56 AM
Kee1pride's Avatar
mines been off over a month now. it'll be fine. but when ever you can, get the sucker back on. im buying a carbon fiber one on friday to finally get it covered. not in the mood to dremel down the stock one
Old Apr 24, 2006 | 10:02 AM
sleet's Avatar
Why are people talking about the valve cover? Are people not able to read?
Old Apr 24, 2006 | 10:22 AM
Derek888's Avatar
why do you need to dremel down the stock one?
Old Apr 24, 2006 | 10:24 AM
EVOONYOASS's Avatar
Don't do it! I did that on my previous car(Eclipse gst) and something got caught in the cams. Once something gets pulled into the cams its already too late in most cases.
Old Apr 24, 2006 | 10:30 AM
gsujeff55's Avatar
umm, because the original poster said CAM COVER. the only cover over the cams is the valve cover.
Old Apr 24, 2006 | 10:38 AM
sleet's Avatar
He has a 35R equipped EVO plus other goodies, I think he's got enough common sense to not try to drive around with the valve cover off.
Old Apr 24, 2006 | 10:39 AM
gsujeff55's Avatar
how did something get in your cams from driving with the cam gear cover off?
Old Apr 24, 2006 | 10:40 AM
gsujeff55's Avatar
i didn't check his sig for validity on his post....but he should know the correct name for what he's talkin about.
Old Apr 24, 2006 | 10:42 AM
WrX Kila's Avatar
I drive with my valve cover off all the time! No problems here.
Old Apr 24, 2006 | 11:28 AM
sleet's Avatar
Oh my.
Old Apr 24, 2006 | 11:30 AM
forum04pl's Avatar
^hahaha
Old Apr 24, 2006 | 11:58 AM
EVO8TOR's Avatar
Get your part name right, damn
Old Apr 24, 2006 | 12:00 PM
EVO8TOR's Avatar
There is no way in hell you can ride around without a valve cover, what keeps the oil from spraying out, you will also loose oil pressure, no way....
Old Apr 25, 2006 | 10:09 AM
SSKILLA's Avatar
what are the chances of something large or strong enough getting into a cam gear tooth and screwing everything?.....i mean if all the covers are on except for the cam gear cover you should be fine.......its not like we run with our hoods off .....
i dont go off roading and rain shouldnt be a problem
Old Apr 25, 2006 | 10:18 AM
hotrod2448's Avatar
I'm pretty sure that was joke. Playing on the whole cam cover/ upper timing belt cover name misuse.
