350 whp on stock turbo possible?
Old May 1, 2006 | 11:06 AM
Kee1pride's Avatar
warrtalon, i thought you made 347 whp?
Old May 1, 2006 | 11:08 AM
Warrtalon's Avatar
Kee, I made 341whp/361wtq at sea level, then moved to Colorado and promptly ran 296whp/325wtq.
I see no way for this guy to do 350whp on the stock turbo with another 800' of altitude and hotter temps (on average). I ended up doing 300whp/337wtq with all my mods in 90 degrees. I don't see another 50whp anywhere...
Old May 1, 2006 | 11:12 AM
Kee1pride's Avatar
Gotcha. Damn that sucks. I was sure we'd be seeing some 11's from you any month now too.
Old May 1, 2006 | 11:28 AM
KOEvo's Avatar
I agree with Warr, i don't see it happening.
Old May 1, 2006 | 11:29 AM
Warrtalon's Avatar
I'm considering driving 500 (one way) miles to Topeka, which is the closest track that is around 1000' altitude just to get that elusive 11. It's not happening up here on the stock turbo...
Old May 1, 2006 | 11:37 AM
jrsimon27's Avatar
yeah freind you should go and find out i would like to see the difference in altitude
i think you can make an 11.3,11.5 with your setup
Old May 1, 2006 | 11:45 AM
Warrtalon's Avatar
Hah, maybe an 11.8 if I'm really lucky, since I gained 0 power from cams and appear to have a messed up head, but we'll see.
Old May 1, 2006 | 11:49 AM
xballsport's Avatar
That sucks, hopefully nothing to serious.
Old May 1, 2006 | 11:52 AM
travman's Avatar
Should have stayed in DC
Btw arent you sponsored by Buschur? wtf arent you sporting the IX 20G? then you wouldnt have to cry around about the altitude and run your 11's in your area and save yourself a 1k round trip?
Old May 1, 2006 | 11:56 AM
jrsimon27's Avatar
hope nothing serious!, but if cams would have given you the power that they do you would be at 11.5 good luck
Old May 1, 2006 | 12:07 PM
Warrtalon's Avatar
I'm sponsored, but I'm not John Shephred, so I can't just get any big money item for free on a whim. I'd like a stock IX or a 20g-9-5, but I'm content right now where I am on the stock turbo. I already lost 400rpm of spool due to altitude, so anymore loss would suck. 11s aren't the end-all to this car - I'm more concerned with road racing and autocrossing - but I'd like to show that I can do an easy 11 without the altitude handicap. I may or may not drive down to Kansas - we'll see.
As for the head, when Al did the cams, we found the exhaust cam caps worn down all on the same side the same amount, and when the new exhaust cam went in, it was binding instead of turning freely, so the head is warped or damaged in some other way.
Old May 1, 2006 | 12:09 PM
Warrtalon's Avatar
Well, for all the "crying" I may do, at least I managed to stay in the low 12s, which I can't say for most of the Evos up here.
Old May 1, 2006 | 12:21 PM
travman's Avatar
Well then I would have to say good job
Just busting your ***** btw....
Old May 1, 2006 | 12:38 PM
TTP Engineering's Avatar
Originally Posted by jmartinez1170
Its possible you just need to spend more then $1,575
I think this is your best post ever.
Old May 1, 2006 | 12:41 PM
Sounds like improper installation and cam caps either out of order or turned 180*.
