utt ohh freeze plug
Old May 1, 2006 | 02:01 PM
Doogie Howser's Avatar
remove your pics ASAP + location in your profile.. and change topic....
Old May 1, 2006 | 02:18 PM
EVIL_EVO_VIII's Avatar
Just spoke to the owner of the car and they told him from what they can see so far, looks like i also suspected, rod gave out...
What i think is that the car had a damaged hg and with time it gave out, causing the freeze plug to come out(happened to me 2x), looks like since all the oil had leaked out, the rods gave out and looks from it like it also might have put a hole through the block
Old May 2, 2006 | 01:22 PM
Just got word that my friends car has 2 blown rods and the factory rep denied warranty!!!!!Block has a hole on it from the rod just as i suspected.. The tech said it was due to running lean
Old May 2, 2006 | 01:34 PM
SMrider102's Avatar
if all the oil leaked out, how could they possibly blame it on a lean condition?? its quite easy to tell....also what about the pistons? that would be another way to tell of a lean condition if they want to blame it on that
Old May 2, 2006 | 01:42 PM
TTP Engineering's Avatar
Someone is screwed. Let me know if you need a motor. I have 4.
Rod definately hit the oil pan.
Old May 2, 2006 | 01:44 PM
thats what i said!! If the car was running lean, most likely he would have taken out some pistons b4 any rods got damaged.. Im curious to find out what cause all the oil to leak out?... Most of the techs dont know jack and just come to incorrect conclusions about what caused the damage
Old May 2, 2006 | 01:45 PM
The rods put 2 holes through the block, hes gona get legal action against
Old May 2, 2006 | 02:02 PM
Lean>High EGT>Detonation>Smashed Rod Bearings>Spun Rod Bearings>Un-oiled Rod Bearings>Seized Rod>Broken Rod>Broken Rod through Block Wall>THE END.
Old May 2, 2006 | 02:04 PM
Thanks for the simple breakdown But what caused the oil to leak, thats the question?
Old May 2, 2006 | 02:19 PM
What came first, the chicken or the egg.
Old May 2, 2006 | 02:27 PM
jqturbo's Avatar
Ooooo, ooooo, I know this one.....um.....mmm....wait, what?
So how did this happen at 30mph w/no boost as a previous post said??
Old May 2, 2006 | 02:33 PM
stevEVO8's Avatar
Dumba$$ it was the chiken!!
Old May 2, 2006 | 02:37 PM
They still havent taken the oil pan out or the head to see if any pistons were damaged
Old May 3, 2006 | 10:59 AM
Quick update:
they took the oil pan off and they told him the oil pan studs broke off, the oil leaked out and rod#1 snapped in half. They havent denied warranty yet, they will tear down the rest of the block tomorrow and take it from there..... To me this sounds like a factory defect, bad assembly, i call bs on this being caused by the car running lean as they had told him originally
Old May 3, 2006 | 11:07 AM
slyspeed IX's Avatar
ahhh
<<<<??????>>>>>>utt ohh ?????>>>>><<<<<?????<<<<>>>>
