Magnetic Drain Plug
Old Apr 13, 2003 | 10:54 AM
shawnhayes's Avatar
Magnetic Drain Plug
Has anyone installed a magnetic drain plug on their EVO?
While the benefits MIGHT be dubious, I have had a magnetic drain plug installed on all three of my Honda motors over the last 11 years and over 170,000 miles with no problems.
When changing the oil, there has been a SIGNIFICANT amount of magnetic material stuck to the magnet in my previous motors.
Of note, the EVO's drain plug is EXACTLY the same thread pitch and size of my old Honda's. (Spoon, a well known Honda tuning shop, even sells magnetic drain plugs for Hondas transmission and oil pans).
Anybody have any thoughts on this? Any clearance issues inside the oil pan?
Shawn
Old Apr 13, 2003 | 11:02 AM
Fireball's Avatar
Was thinking about that myself. If you get one working, let me know, I'd like one too.
Old Apr 13, 2003 | 11:34 AM
shawnhayes's Avatar
Ok, it looks like I'm going to have to be the pioneer, but I might need some minor advice:
Has anybody had the oil pan off a 4G63? What kind of clearance do I have to the crank or windage trays?
The stock plug is VERY short. Replacement magnetic plugs are commonly 1" to 1.5" long. (the spoon one is 2", but the Honda motor has A LOT of clearance from the oil pan).
Shawn
Old Apr 15, 2003 | 08:04 PM
jfh's Avatar
jfh
The drain plug should be located at the deepest part of the sump for obvious reasons. Crank should not interfere at this location. Should be able to check clearance to windage tray when changing oil. I'll check mine this weekend when I do the change if no one posts prior.
Old Apr 16, 2003 | 03:41 PM
mayhem's Avatar
does the evo not already have a magnetic plug stock? all the cars I've changed oil on have had it. They also have had magnetic plugs in the diffs and trannys
Old Apr 16, 2003 | 09:23 PM
shawnhayes's Avatar
Nope. The EVO doesn't have a magnetic plug in the crankcase.
Neither have either of the previous two Honda's I've owned.
The 96 EX 4 door Civic, however, DOES have a magnetic drain plug in the automatic transmission.
Anybody remove their transmission or diff drain plugs yet?
Shawn
Old Apr 17, 2003 | 09:10 AM
mayhem's Avatar
Really? Man that's weird. Most my experience has been on Nissans, Fords and Chevy's, so this will be something I'll check into on the Mitsu. Definately want to protect those diffs!
Old Apr 17, 2003 | 09:25 AM
flybyevo's Avatar
Re: Magnetic Drain Plug
Shawn
Shawn,
I had mine drain plug out on Tuesday for the first oil change. The plug was very short. The spot on the end was black. I didn't notice any metal stuck to it. I didn't check if it was a magnet either. From what everyone is saying it probably is not.
Old Apr 17, 2003 | 09:08 PM
shawnhayes's Avatar
Re: Re: Magnetic Drain Plug
Originally posted by flybyevo
Shawn,
It isn't. The end spot is black because it is PAINTED. I have a little trouble understanding why on earth they'd want to paint an assembled oilpan both inside and out with the drainplug installed. I just can't figure it.
Shawn
P.S. for everybody's benefit, I'll be installing a magnetic drain plug at the next oil change. Hope nothing bad happens.
Old Oct 16, 2003 | 03:18 PM
highenuff14's Avatar
So, has anyone found out what thread pitch and size of drain plug for the Evo? I'm looking for some magnetic plugs but can't buy without exact size.
Old Oct 16, 2003 | 03:37 PM
n00dle's Avatar
14x1.5
Old Oct 16, 2003 | 04:03 PM
webguy330i's Avatar
The diff and tranny drain plugs are all magnetic. Your tranny plug is quite large too, probably covered in metal bits right now.
I'd like to know if anyone gets an oil drain plug that's magetic. Keep us posted!
Old Oct 17, 2003 | 04:45 AM
shawnhayes's Avatar
Got one. I haven't had a need to remove it yet. I'll get a photo or two when I get it out.
Shawn
Old Nov 3, 2003 | 09:52 AM
CombatCQB's Avatar
Where is everyone getting their magnetic drain plugs? I searched Ebay and found a bunch for Hondas, Mazda, BMW etc. Any of those share the same thread patter?
Old Nov 3, 2003 | 10:05 AM
evo_007's Avatar
They've got them at Pepboys.
