which downpipe 2.5"or 3"
Originally posted by dmora
The evo is a new car for the US. And japanese reviewers are notoriously biased, even more so than US mags. All things come with time, but using common sense and knowing basics of mechanical engineering will never steer you wrong.
In this case, we want an exhaust/downpipe combo which yields the most power. The mechanics behind a turbo would dictate a larger hole/pipe to kick out the exhaust will allow the turbo to work more efficiently, thusly creating more power.
MANY of the exhausts you see on the market are purely rice mods. Full of bends and rediculous resonators for tips. Look at the big turbo cars and race cars. Its a big pipe, no fart can on the end.
but what do you think about the tubular exhaust manifold
will it help the exhaust breath easier too?
is it worth 1000 bucks?
pete
I am going with a full Bushur racing 3" setup. I will post the results after its all installed. Dont forget to do a air intake kit as well. www.bushurracing.com
Originally posted by petem
daniel thanks for the explonation
pete
pete
Originally posted by atlvalet
If anyone has seen a picture of the Evo's engine, the turbo/wastegate dumps into an elbow before it gets to the downpipe. My question is, how much hp could be gained from replacing that? (assuming 3" turbo-back exhaust has allready been installed)
Other than sounding REALLY FREAKING COOL/LOUD, I dont believe it gives any extra power.
This may help clear up some of the "urban legends". Here is a link to a technical discussion that answers several questions concerning exhaust diameter. It is pretty good and not to technical.
The article is hosted by Vishnu Tuning and I thank them.
http://www.vishnutuning.com/exhaust101.htm
Also, before some folks consider spending $1000 for tubular manifolds, I recommend you first determine you performance goals, then plan the proper parts and install them in the correct order to prevent wasting money.
Speedlimit.........
Speedlimit.........
Here is a Q&A from a different thread that you may find useful:
From Shiv @ Vishnu Tuning: "The cat-back upgrade alone yeilded a 10 wheel hp gain over stock with torque gains at all engine speeds. Neither an open intake, free flow cat (or even a test pipe) showed such across-the-board gains. This is why it is a part of the kit. We don't make it a habit of integrating components with marketining purposes in mind".
Follow-up question:
"You mention testing with a free flow cat and test pipe but, no mention of downpipe testing. I have seen much written about the restrictive stock downpipe. I am curious why you have not chosen to replace it with a 2.5" or 3" mandrel bent piece. You can still retain the stock catalytic converter (which is reported to flow quite well) with the 2.5" down pipe in order to meet CARB requirement. Some tuners recommend this as the best bang for the buck mod available for a stock EVO. Do you plan to do any testing here? Seems as though it would be a logical piece to include in your Stage Zero."
Shiv's Response:
"Controlled backpressure testing (read from the exhaust manifold) suggested that the muffler was a bigger contributor to back-pressure than the downpipe or cat. And since knock is the limiting factor when tuning on pump gas, back-pressure (and the resultant exhaust gas reversion) is our biggest enemy."
More info available from www.vishnutuning.com
Follow-up question:
Shiv's Response:
Do you mean running open wastegate?
No, no, no...The downpipe attaches to an elbow which attaches to the turbo. The Evo downpipes do not attach directly to the turbo, unlike WRX downpipes. I vaguely remember seeing a turbo elbow on the Mines site. How much turbulence does this stock elbow cause, and how much will spool-up be helped by replacing it, if at all?
Does it look like mesh weave. These are normal as well. How much turbulance they offer is hard to say. In truth you would want the smoothest airflow, but i doubt it would make that much of a differnce so close to the exhaust wheel.
No. It's not a flex joint. Go to mines-wave.com and click on Evo VII. You'll bring up a few pictures. One of them is the joint (it's got a divorced section for the wastegate). I think they call it a "coupler." You'll see what I'm talking about. You can also see it in a picture of the Evo 4G63 with all attached piping (sans chassis).
cbseven
13
Feb 19, 2012 05:36 AM
evovin
Jan 27, 2009 11:50 AM
Ibspoolin
Jul 5, 2005 06:39 PM
GottaGoFaster
12
Feb 21, 2004 06:35 PM
