Rough Idle, no cams
Old May 9, 2006 | 07:25 AM
Ph3n1x's Avatar
Rough Idle, no cams
Just wanted to check and see if other drivers experience a rough idle with no cams. When my car idles it vibrates slighltly on and off and stutters slightly. From the rear the exhaust belches once in ahwhile.
Has anyone else experienced this or is this something thats normal?
Old May 9, 2006 | 08:48 AM
jmartinez1170's Avatar
Sounds like you have a intake or a drop in filter. You will not get a rough idle on a stock trim car if you do take it to mitsu.
Old May 9, 2006 | 09:02 AM
Ph3n1x's Avatar
So its normal with an Intake?
Old May 9, 2006 | 09:19 AM
Yea for some reason the maf on are cars dont like the added air. There are a boat load of threads about intakes and bov are killing the car rough idel rpm droping all that good stuff. The best way to get rid of it is one of 2 things 1 HKS EIDS i used it it worked like a champ 2 get your car flashed for the money the HKS EIDS is the better way to go its around $110-130 to get one. VS a flash that can run much more you will get more power but once you add more mods you will have to retune every other mod.
Old May 9, 2006 | 09:23 AM
STI HIT MAN's Avatar
Try hooking up an vac. gauge to the manifold. Adjust the idle air screw till maximum amount of vac is achevied.
Old May 9, 2006 | 02:14 PM
Ph3n1x's Avatar
Well I am flashed for all my mods...
HKs Rs intake, TBE, FP, EBC, APS Bov.
Old May 9, 2006 | 02:15 PM
Ph3n1x's Avatar
Could it also be a dirty maf?
Old May 9, 2006 | 02:19 PM
badhabit90's Avatar
check your plug wires. one may have come loose causing a rough idle.
also, did you change your plug wires?? stick with stock. magnacore seems to have a crossfiring issue, just ask smokedmustang...
Old May 9, 2006 | 02:28 PM
No its the intake the tuner maybe doesnt know the codes to get to the maf to reset some of the air flow the only person i know who does it good on the first shot is jester tuneing. Im not trying to start anything this is the point where im going to tell you to do some research there are many threads like this if you dont want it to happen any more buy the hks eids it will still stall but it wont hurt the car or turn off rpm will drop but you wont feel the car wanting to die. Either you spend the money or you learn to live with it.
Old May 9, 2006 | 02:34 PM
Ph3n1x's Avatar
And jester tuning is thjey guy who did my flash
Old May 9, 2006 | 02:36 PM
Ph3n1x's Avatar
Dont get me wrong it is in noooo way dieing on idle, its just a little rough, especially when its cold.
Old May 9, 2006 | 02:56 PM
every evo when its cold has a rough idel.
at least you have a stock ecu i got a aem it take me 8 mins to get my car to start when its cold out some dont tell me about cold starts
Old May 9, 2006 | 02:59 PM
bluebyu36's Avatar
yo phenix i had the same problem and come to find out my the egr was disconnected
Old May 9, 2006 | 04:10 PM
Ph3n1x's Avatar
Now can someone tell me where the EGR Valve is located...lol
Old May 9, 2006 | 04:14 PM
bluebyu36's Avatar
do a search it's behind the throtle body
