Few questions about cams?
Old May 14, 2006 | 04:18 PM
Evolution8Blue's Avatar
OK first if you dont bleed the lifters and it ticks what does it do? any damage or anything?
What does the ticking sound like how loud is it? Becuase if installed mine and ran then for over a day with alot of driving and the only time theres really any noise is when its cold and warming up and its only right right next the the most forward cam gear and its not loud at all you have to listen for it...is this anything to worry about.
What happened if the timing on the cam gears is right but it possible sliped a tooth on the crank shaft.......the install went great and ive brought the car to 5k nothing out of the ordinary has happened or anything, no check engines im just scared and want to make sure everything perfect....Because the install really did seem to easy.
thanks alot i really appreciate it.
