My Car Died
Old May 20, 2006 | 03:10 PM
PEOPLExpress's Avatar
My Car Died
I was in the process of driving, did a little acceleration through a turn, and then next thing a I know, I have no power. For some reason my car lost all power. Any ideas what it could be???
edit: car will not start now and got towed away
MODS:
catback exhaust
test pipe
intake
base dynoflash
staatz's Avatar
Marsh, check your IC pipes..maybe one came off..
Old May 20, 2006 | 03:15 PM
nhsean69's Avatar
Does it crank and not start , or just do nothing at all when you turn the key?
Old May 20, 2006 | 03:17 PM
it just doesnt kick over, it wants to start but just keeps makin the sounds
Old May 20, 2006 | 03:19 PM
nhsean69's Avatar
did you check to make sure the MAF harness didnt come unplugged or maybe 1 of the ECU plugs werent fully clipped when you put the ECU back in after the flash. When was the last time you did any modification to it??
Old May 20, 2006 | 03:23 PM
i was at pruven performance for the dyno flash, ecu has never been removed, i put my test pipe on a couple weeks ago
Old May 20, 2006 | 03:24 PM
there was also no weird noises or anything before it died, the car just died
Old May 20, 2006 | 03:31 PM
Danny23's Avatar
You put the test pipe on after the tune?
Old May 20, 2006 | 03:33 PM
yes i did, i was told by other members itd be fine
Old May 20, 2006 | 03:40 PM
MalibuJack's Avatar
Sounds like one of your intercooler pipes popped off.. It seems to happen to everyone on occasion.. Even stock cars have this happen on occasion..
Old May 20, 2006 | 03:41 PM
wouldnt that make some noise if that happened?
Old May 20, 2006 | 04:00 PM
nhsean69's Avatar
Ive been in my buddies evo when the IC pipe at the TB popped off, It didnt just die until he coasted for a second with low RPM's and when it did die, we were able to start it but it would die immediatly afterwards. I would definatly check it tho, its just one more thing you can check off the list.
Old May 20, 2006 | 04:12 PM
NvsEvo's Avatar
did u check your fuses?
when i installed my test pipe, the o2 sensor wires fried from the heat, which made one of the fuses to blow....maybe that could be one reason
Old May 20, 2006 | 04:21 PM
joseph k's Avatar
maybe your alternator quit and now your battery is drained, just another thing to check off
Old May 20, 2006 | 04:43 PM
fsugatorbait's Avatar
Id check your fuses. You were going around a corner at a good pace when this happened so it's possible that a wire shifted and grounded itself which popped the fuse.
