Should I change oil after 600 mile break in
I changed mine at 600 miles. I don't see how it can hurt.
I did look for metal shavings in the old oil though, and couldn't find any that were visible to me.
It might be a waste, but I had a good peace of mind, and its only like $30 to do (yourself)
Yes, fresh oil is cheap and good for your engine. But, you have to look at "break in" as well. Those particles that may be in the oil during the break in period ARE beneficial to the break in process as they help the mating process of the internal parts. Many engine builders will tell you that people have ruined new and freshly rebuilt engines by not allowing the oil to do it's job in helping with final break in.
However, that said, my suspicion is that Mits has done a very good break in at the factory. I say this because they use synthetic from the factory whereas dino juice is the preferred break in oil.
That's a GOOD thing. If that's true, then changing your oil so early won't hurt anything except your wallet. There really is no good reason to throw away perfectly good synthetic oil. It costs more because it does more. Spend the money on the best oil filter you can get, that will help more than throwing away perfectly good oil.
GR-VIII
GR-VIII
Originally posted by Event-Horizon
I'm pretty sure its factory fill Mobil-1 5w-30
