Not runing stock maf sensor can i just put a filter right on the turbo?
Old May 24, 2006 | 05:08 PM
Evolution8Blue's Avatar
ok i got the 3" maf sensor blowthrough with the ecu+ my question is now that i dont need that intake pipe for anything but the filter can i just bolt a filter right on the inlet on the turbo....what size and where can i get the filter...does anyone have this...and is it going to help with spool or do more harm then good cause heat
Old May 24, 2006 | 05:31 PM
BADEVO's Avatar
Use the intake pipe MINUS the maf.
Old May 24, 2006 | 05:36 PM
MalibuJack's Avatar
Well, yes and no.. I wouldn't do it because of the location, it can get wet or draw water through it.. Depending on the turbo, stock 3" I would definitely run an intake pipe though, route it up away from where dirt and hot air can get directly into it.
Old May 24, 2006 | 06:14 PM
TrinaBabe's Avatar
I would keep the intake on it with the filter on the end of it. That is how I do it. At the track I do remove the whole assembly.. my air filter does cause a ~1-2 mph drop in my trap speed if I leave it on. Obviously driving around town this would be extremely detrimental to the turbo.
