What the hell is wrong?
Old Apr 18, 2003 | 09:58 AM
jotan82's Avatar
ok, i have the HKS type 1 TT
i plugged the harness havn't tapped the park brake wire yet, nor the RPM wires, but the TT won't work...
it doesn't keep the engine on after i turn the car off... wussup with that?
the harness plugged perfectly...
when i turn on the car the TT turns on, and it says 1:00 min
but it doesn't keep the car on...
what is the problem? is it just a faulty TT or it is user error?
tnx for your help
Old Apr 18, 2003 | 06:16 PM
evo_dan's Avatar
I'm not an expert but it may have something to do with the park brake wire not being connected yet. The TT is designed to turn the engine off if it detects the park brake light is off. This is a safety measure to ensure no one can steal the car while it's parked with the engine running. Try connecting the park brake wire to see whether or not this is the cause.
Old Apr 22, 2003 | 09:22 AM
jotan82's Avatar
got it installed... it wasn't working cuz there was no power going to the ground wire if you don't have the wires spliced...
you mod and you learn
