Mandrel bent or not?
Old Apr 18, 2003 | 01:51 PM
stvbreal's Avatar
I just got the full turbo-back exhaust from Buschur, had it sent to my buddie shop. He said it aint mandrel bent. He may be on crack, I dont know. Can anyone verify this? I don't think they would adv. this on their website if it wasn't mandrel bent.
Old Apr 18, 2003 | 02:12 PM
broeli's Avatar
Do you have pictures? It's not mandrel bent unless the piping is of uniform size throughout the bends, etc. Non-mandrel will have dent type marks where they are bent.
Old Apr 18, 2003 | 02:14 PM
Coolguy949's Avatar
looks good to me......
I would say your best bet at getting an answer would be to post on the message board there since Dave himself answers the posts or just call and ask for him.
http://www.buschurracing.com/contact.html
Old Apr 18, 2003 | 02:33 PM
stvbreal's Avatar
He must be on crack then. I j ust needed closure.
Old Apr 18, 2003 | 04:14 PM
2Cool's Avatar
Yep, if it wasn't mandrel bent then the inside corners would have crinkles where the metal was slightly folded.
Old Apr 19, 2003 | 11:59 AM
mrdecibel's Avatar
I have attached a pic of my Buschur exhaust. There are no folds. The only abnormality are the rings before and after every bend. My guess is this is where they attach the equipment to perform the bends. Notice the banding in the pic. I am sure someone on this board can confirm if these are common in the mandrel bending process.
Old Apr 19, 2003 | 12:13 PM
MalibuJack's Avatar
That is absolutely mandrel bent.. The metal would have folds in the inside corners of any bend if it was not.. sort of like the folds you get in your stomach when you sit down and hunch over.. We as humans need to be mandrel bent..
And yes.. the defects you see are caused by the fixtures that the pipe is held by.. as long as their not real deep (affecting the diameter) Its actually caused by a small amount of metal "Flowing" towards the fixture when its being worked.. as long as it doesnt affect the inside diameter of the pipe, or have very drastic kinks from really sharp corners (sharp corners in themselves would cause a restriction) at that point, you should be OK..
Old Apr 19, 2003 | 12:23 PM
rpmvideo's Avatar
Re: Mandrel bent or not?
How do you like the set up ? How long have you had it ?
anyone else had experience with Buschur products for their evo ?
-Nate
Old Apr 19, 2003 | 10:53 PM
Turboniam's Avatar
He's been making/selling/modding DSM/4g63 i.e. the EVO predecesor for years.
Old Apr 19, 2003 | 11:31 PM
stvbreal's Avatar
the score marks threw me off.
Got the system on and it it's the ****. Witht the test-pipe its quite loud but I like it. I will be getting the hiflow cat too. Easy install. Did it my garage with ramps.
Old Apr 20, 2003 | 09:08 PM
jfh's Avatar
jfh
It's definitely mandrel bent. Ring marks are from jig used to hold tubing during bending process.
Old Apr 21, 2003 | 09:59 AM
Fireball's Avatar
Can you feel a difference in the performance of the car?
Old Apr 21, 2003 | 11:48 AM
BLKEVO8's Avatar
Has any put in the air intake from Bushur and experience a suction sound in the defraust vents in the cabin. I put in a full 3" bushur exhaust and intake Sunday. Next week I will do the manual boost and AFC. I am wondering is this is a side effect of the air intake if so the old box goes on with a drop in filter.
Old Apr 21, 2003 | 12:02 PM
stvbreal's Avatar
Had to turn the boost down 2psi after installing. Less lag, great sound but may be a bit too loud for some. I couldn't beleive how heavy the stock exhaust is, good lord ! Gonna get the hiflow cat by Friday and see if there is any diferference in noise and or performance. Also geting the Buschur filter kit and hopefully they will have the mini battery too.
Just talked with the guys at Buschur. Well no mini battery yet but I got the air filter coming and decided to hold off on the hiflow cat, I like how it sounds.
Quick question off topic, Apexi S-AFC, anyone now how to isntall and tune it? Kinda new to it, I understand it's fucntionality but need a little insight.
Old Apr 21, 2003 | 01:57 PM
mobius97's Avatar
Man I bet that gave you a good boost in power...any boost spiking caused by it?
