BOV Question
Old Jun 11, 2006 | 08:13 AM
9xfaster's Avatar
I put a Forge BOV on my car, and I couldn't drive my car normal. It would sputter like crazy. I would adjust the stiffness of the spring also, that didn't help. And it also wasn't letting boost raise above 15psi for whatever reason. I put the stock one back on and I'm running fine.
I'm running 30psi tapering down to 28psi and the stock bov is fine.
Old Jun 11, 2006 | 09:13 AM
Warrtalon's Avatar
Just stick with the stocker. I don't know why you keep mentioning the Greddy over and over. The stocker is great and costs you nothing.
9xfaster, the Forge BOV can't make you only run 15psi, so that was a faulty install.
Old Jun 11, 2006 | 09:32 AM
WhIte06evO9's Avatar
well intentionally it was the greddy rs or the tial i was going to get but if stock is better then why change it and risk getting a leak ya know
Old Jun 11, 2006 | 09:36 AM
Warrtalon's Avatar
Do you mean "initially"? I don't see how the Tial would even come into the equation - it's made for big turbo setups running VTA. The Greddy...well, the only reason that would come up is because of its brand name. If you upgrade, get a Forge RS or APS - preferably the Forge since it is 100% recirculating.
Old Jun 11, 2006 | 09:45 AM
dan628's Avatar
Just go with the APS, its a great piece, everyone who has it loves it, just get that one and you'll be very happy!
Old Jun 11, 2006 | 09:46 AM
are alot of people having problems with theres?(forge)
Old Jun 11, 2006 | 10:01 AM
2muchboost's Avatar
Originally Posted by SKILMATIC
On a evo 9? How are you not stalling? Every single evo 9 owner with a aftermarket BOV stalls unless they recirc it. Do you have an aftermarket intake with a flash?
I don't know? I am flashed, but even b4 that I never stalled, and it is vta... I have the ver. 2, maybe that's it?
Old Jun 11, 2006 | 11:28 AM
SKILMATIC's Avatar
O ok well like I said its a recirculating BOV therefore you wouldnt have any problems. The vta is a recirc BOV. So basically its the same as the stock 1G evo 9 BOV . You basically waisted your money dude.
Old Jun 11, 2006 | 11:31 AM
so anything thats recirculating would work but its a waste of money
Old Jun 11, 2006 | 11:32 AM
SKILMATIC's Avatar
Well yeah because the stock evo 9 bov DOES THE SAME THING. If you have a 8 I would buy the oem evo 9 BOV. Thats just my opinion.
Old Jun 11, 2006 | 12:45 PM
2muchboost's Avatar
What?? my set up is NOT recirculating. How is it the same as stock? I have the ver. 2 that comes with the upper ic pipe...
Old Jun 11, 2006 | 01:27 PM
Warrtalon's Avatar
2muchboost, even if you don't feel the symptoms, you are venting metered air, which is causing your ECU to provide more fuel and thus a rich condition between shifts. That is not good for performance.
Old Jun 11, 2006 | 02:22 PM
2muchboost's Avatar
Ohh.. I see what you're saying.. The hks is good for holdinging high boost, I don't really want to get rid of it. Could I not just recirc it?? By the way. If vta is not good for our cars why do so many people use them? I've seen 400hp time attack cars and 600hp drag cars with vta bov's? Why do they use it? {I'm just wondering} thanx..
Old Jun 11, 2006 | 02:29 PM
occultworks's Avatar
Because they use MAP instead of MAF. Do a search on it.
Old Jun 11, 2006 | 02:31 PM
trinydex's Avatar
well im flashed already im running 368whp 351tq with exhaust, intake(cone/adapter) forge boost controller, hks 272 cam walbro 255fuel pump..and now im going to be adding methanol and getting re tuned again so what do u guys think for a bov off valve good?
what happened to searching the end all bov thread to get your answers?
