forge mbc and spiking issue
Old Jun 15, 2006 | 04:51 AM
sandm's Avatar
first off, thanks for gettin rid of zemehl
I would assume, as mentioned above, that the mbc would not care about the gear it's in, just how much pressure it takes to push up the spring and ball, so if you have it set at 21psi in 3rd, then at 21psi in first, it would open as well?
Old Jun 15, 2006 | 08:16 AM
vwjeff's Avatar
Because of this problem, I was going to install an AVC-R. I don't even want to deal with this problem.
Old Jun 15, 2006 | 08:21 AM
EvoDan2004's Avatar
with the avc-r you can control boost in all gears right. i like that as a mbc cant. but they are right the higher gear the more boost more load. dont set it to 21 in 1st. i did mine in 3rd. in 5th im hiting 21 and 1/2 to 22ish. no problems.
Old Jun 15, 2006 | 09:29 AM
Boltz.'s Avatar
FCOTM Winner
^ Are you positive that you have the spring seated correctly? There is one end that is larger that is supposed to hug around and fit snugly onto an internal part of the MBC.
When I first set up my MBC I just had the large spring in there are had the same problems as you, because the spring wasn't seated. I broke it open and seated the spring and since have had no problems.
galantman03
43
Feb 5, 2017 09:54 PM
meat_EVO
May 26, 2008 03:52 PM
gregfromblur
Sep 20, 2006 01:35 PM
TURBevO8
11
Aug 24, 2006 08:49 AM
umiami80
Feb 15, 2004 06:59 PM
