blow by after break-in.....
Old Jun 14, 2006 | 09:56 PM
SlowCar's Avatar
any point putting in dinosaur oil/non-synthetic? I did the break in period with mobil 1 that came with the car and still having some blow by after break in period.
Old Jun 15, 2006 | 12:28 PM
C6C6CH3vo's Avatar
Since day one, my car has collected about 1ml of oil a day coming out of the ventilation check valve
Old Jun 15, 2006 | 12:33 PM
smokedmustang's Avatar
I thought you use Dinosaur oil for the first 1500miles, it picks up more junk. after 1500miles, use synthetic! That is what I am doing with mine, starting today.
change oil after
first 20 miles
at 500 miles
at 1500 miles.
Dyno oil ONLY 10-30
then 20-40 with balance shaft eliminator kit.
Those are the rules I was told, and the ones I am sticking with.
Old Jun 15, 2006 | 02:15 PM
Yeti's Avatar
it is not a good idea to break a motor in on synthetic oil. it has to much load carry capcity which doesn't allow the rings to seat properly with the cylinder walls. We always ran cheap oil for the break in period
Old Jun 15, 2006 | 04:42 PM
SlowCar's Avatar
so, should i go back to dino oil and hopefully it will minimise more of the blow by?
Old Jun 15, 2006 | 04:58 PM
badhabit90's Avatar
might help for seating quicker...
Old Jun 15, 2006 | 07:37 PM
dubbleugly01's Avatar
How are you measuring blow by to determine it's a problem? If you're stock, how do you know how much blow by you have?
Old Jun 15, 2006 | 07:47 PM
krazirob's Avatar
what kind of oil are you guys using after break in??. i just got me an oil change at 1500 miles and i put royal purple in it. its basically synthetic just like the mobil1
Old Jun 22, 2006 | 09:38 AM
kjewer1's Avatar
Originally Posted by smokedmustang
change oil after
first 20 miles
at 500 miles
at 1500 miles.
Based on my experience with several built motors and factory rebuilds in my 2g, I would change the oil even more often than that. The 20 is good. If I'm feeling ambitious though I do it after heat cycling it twice to check for leaks. I do it again at 100, 500, 1000, and 2500, then go to regular 2500 mile intervals. Roughly. I think I change my philosophy slighty each time I go through it. Cheap oil is ok, but use good filters. I usually do the filter at the 20, 500, and 1k mark IIRC.
