Oil Change today, good info
I just did my first oil change today on my IX at 1100 miles and I was really shocked how easy it was. I've seen various methods on doing oil changes but to me the absolute easiest way is removing the front passenger wheel. This gives you complete access to the oil filter and the drain plug without having to lay down in awkward positions underneath your car. It makes the wrenching easy because you can clearly see what your doing, so you dont have to worry about cross threading the filter or the drain plug because of a bad angle or something obstructing your view. I had this problem on my previous cars because I couldnt actually see what I was doing I could only feel, and it was often in very tight, awkward positions underneath the car. With this method you can pretty much do everything w/o laying down, which is a big plus. Just remember to jack your car up safely and properly retorque the wheel when you're finished. It only took 40 minutes while bsing and letting it drain until the very last drop. I'll only change my oil this way from now on, it makes it a lot simpler and WAY less frustrating. Highly recommended
Thanks for the pointers. Did you need a handtool to get the filter off, or is it accessible by twisting it with just your hand?
This will be my first change on my evo this weekend. Any other pointers would be great!
Originally Posted by MuslimEvoFreak
Haha, your hands won't cut it man. Get an oil filter wrench and that should do the trick.
Is this just because of the location? Sorry i haven't done much searching as to where the filter is located. All the other cars i've had, i could untighten them with my hand...
Ramps wont work if you car is lowered and I never needed a oil filter wrench to get it off. To do my oil changes I will just jack up the car from the passenger side and I would have plenty of room.
Originally Posted by MrMejia
Ive taken it off by hand since day one.
I usually put it on Rhino Ramps. I dont think you would want it flat, but rahter tilted up to let all the oil drain out. I sometimes use a jack also, once the car is on ramps, to jack it up even more and watch more oil come out.
I would think taking the passenger wheel off is too much hassle. Driving it up onto Rhino ramps takes 1 minute.
definitely ramps are the easiest way... only thing i always have a problem with... when you take off the filter, oil always gets all over your hands... any fix to that ? if you go to autozone they have an important oil filter attachment that goes on the end of a ratchet... fits all sizes, its a great tool
better go do it..haha thanks
