Amsoil Or Bg Syncro Shift Ii
Old Jun 19, 2006 | 07:54 AM
Drift4's Avatar
Need to know which oil is more favored? I have the BG man coming to see me this afternoon to give me gear oil for 11.00 a quart vs AMSOIL theat I found for
8.74 but it is GL4 specific. Has anyone tried both lubricants? Or what is your take
http://www.bgprod.com/products/driveline.html -- 11.00
https://www.amsoil.com/storefront/mtg.aspx -- 8.75
Old Jun 19, 2006 | 08:58 AM
barneyb's Avatar
If I were to rank transmission oils
#1 - the oil Mitsu specifies for the 6-speed MR
My second choice would be the lubricant specified for the Evo 5-speed
My third choice is the BG product
Old Jun 19, 2006 | 09:19 AM
Silk's Avatar
doesnt recommend any particular type of tranny fluid for the 5sp, they just specify the viscosity.
Old Jun 19, 2006 | 11:03 AM
barneyb's Avatar
Yeah, per the service manual, you are correct. However, the lubricants available from the dealer are tailored for our cars. I have the oil for the 5-speed in my shop but I don't see any part number on the label. The lable reads "Diamond Gear oil 75W-85".
The lubricant part number for the 6-speed is M2313376.
Old Jun 19, 2006 | 11:07 AM
thetox's Avatar
BG Synchroshift II = shifts like butter. second change of the trans fluid on my car and i couldnt be happier
Old Jun 19, 2006 | 11:45 AM
PVD04's Avatar
If the label reads "Diamond Gear oil 75W-85" then it is not for the 5-speed, as the manual calls for 75W-90 in the 5-speed.
Regarding the Amsoil, I have been using it for about 7000 miles and 3 track days without any issues. Before that I used to Pennzoil Synchromesh, but it had a tendency to wear out after ~5000 miles.
-Paul
Old Jun 19, 2006 | 01:20 PM
Drift4's Avatar
I don't know about Mitsubishi Lubricants, except for the ones made for the rally cars "CITIZEN OIL" I will try BG due to my car is an 03 with 17k and just starting to have the dreaded 5th gear grind, from a 4th to gth gear change @6500-7000rpm. So I am sure not gonna dealer screw it up further by trying to replace the syncros....since all my friendS broke after it being repaired...so I will either send it to Shepherd / TRE and get it done the first time. Diaqueen yes I will use for the Transfer case and the Rear Diff, but there are more superior lubricants out there...but hard to get. DUCKHAMS / TOTAL / MOTUL, but it is all a matter of choice, the manual states API GL4 for the gearbox, and straight 90 for the transfer and the rear diff. Now if the BG is not a good oil were it braksdown quickly I will say so, since I have Mitsubishi fluid in there I would like to try something else, but never know I may go try AMSOIL or go back with the factory.
Anyone please your critic is welcome..................
Old Jun 19, 2006 | 02:18 PM
BURNALL_4's Avatar
i went BG II
Old Jun 19, 2006 | 10:46 PM
barneyb's Avatar
-Paul
This transmission lube I have came from a Mitsu dealer. The bucket I
bought was open because they were using it to fill Evo transmissions.
BTW, my factory service manual, this is for an '03, calls for GL-4 75W-
85W or 75W-90. Anyway, the day I brought this stuff home I still wasn't
convinced I had the right oil. But, I had occasion to call Jon at TRE
that day and while I had him on the phone he confirmed I had the right
stuff. This is where I got the recommendation for using the MR oil in
the 5-speed transmission. As far as I am concerned, if it is from Jon's
lips then God has spoken.
As for the BG product, I used it years ago in my DSM. My DSM, like
most, had shifting problems and the BG product helped a lot. Over the
years many concoctions were tried in the DSM trannys. I tried them too.
Some were horrible and some were good but, for me, BG worked the best.
I was especially impressed by how it would drain after 20,000 miles
still looking as clean as when it went in. However, this transmission
eventually got noisy and I had to replace it. The coast-down noise had
increased in volume so much I was convinced I soon would be thumbing a
ride if I didn't do something. So, if the heavier weight lube
recommended by the maker will work without causing shifting problems,
then there may be good reason for using it.
Old Jun 20, 2006 | 12:53 AM
evo150's Avatar
amsoil is what i run in my tranny
Old Jul 18, 2006 | 05:02 PM
maxx4wd's Avatar
another fly in the ointment but I put in BG II and it fixed almost all my shifting problems...but I've only been running it for 5000 miles so I don't have any long term comparisons to help you (all I can say for sure that at least in my car it is 100% better then the stock stuff)
Old Jul 18, 2006 | 06:57 PM
CeeNiK's Avatar
How many quarts does it take to fill the tranny
Old Jul 18, 2006 | 07:28 PM
hk2ronin's Avatar
3 quarts. I did my first change @13900 with bg synchroshift II. THats a killer price for that but I can't seem to find where to order it on that link. I got 3 qts from slowboyracing coming tommorow from the ups man. Im about to change it again @21000 or so. I like the fluid and think it works real well, but straight daiqueen for my transfercase.
Old Jul 18, 2006 | 07:52 PM
4Gsixty3's Avatar
BG II !!!!
Old Jul 18, 2006 | 09:54 PM
Danny23's Avatar
i have the original BG in my trans. and diaqueen in my t/c and diffs. next trans. fluid change i,m going to try the BG11
