**PROBLEM: Greddy V Spec FMIC
Old Jun 24, 2006 | 07:16 AM
Evo05lution's Avatar
Ok, guys this might get a little confusing but bare with me ill try to be as clear as possible...
oK, I just received my Greddy V-Spec FMIC. Im in the middle of installing it and i have the Front Mount mounted, the pipe from the i/c to the uicp mounted...
then i moved my way to the pipe that runs from the turbo to the left side of the i/c. When i was taking the black pipe that runs from the turbo i noticed that, it has the boost sourse for my boost controller. So i looks at the pipe greddy gave me and i saw that there is no outlet for the boost sourse. So my question is...WHAT THE HELL DO I DO?? some one with info please help me out! thanks
Bobby
i was thinkng that i could take that vacum hose n splice it into my BoV vacum line...?? idk
right now my boost controller is going to the wastegate actuator and the turbo outlet...please let me know what to do...thanks again
Old Jun 24, 2006 | 02:58 PM
Anybody Got An Idea???
Old Oct 1, 2006 | 11:20 PM
nvr2fast's Avatar
Bump... I'm planning on getting the Greddy/Trust V-spec intercooler kit as well...
Old Oct 1, 2006 | 11:29 PM
DsmAwdTurbo's Avatar
tap it into your bov line or you can get a nipple welded onto your new turbo outlet pipe.
Old Oct 2, 2006 | 05:01 AM
EVO8LTW's Avatar
If you want to add a nipple to that pipe, it's easy. Just get a 1/8 npt nipple from Lowes or a plumbing supply, and a drill bit and 1/8 npt tap from Sears. Be sure to use teflon tape or sealant on the threads.
Old Oct 2, 2006 | 05:28 AM
deadbeatrec's Avatar
+1
i had the same problem when i installed my buschur fmic. just go to the top of the diverter valve.
