boost LEAKS and aps bov people all help please
Old Jun 28, 2006 | 10:52 AM
unclecomfort's Avatar
wow...I am seeing some super high pressure for the boost leak test.
I did saw some vendor dont recommend anything above 7psi...are they wrong?
Old Jun 28, 2006 | 10:56 AM
EvoDan2004's Avatar
then what would be the point. im going up to 25psi when im done. i only run 21 psi but id rather know the sstem can hold 25. it is fine to go higher then 7 psi. im not gonna go higher then 25 till i get my smc kit installed then il do like 28 ish or so.
Old Jun 28, 2006 | 11:24 AM
bluebyu36's Avatar
so did u drive the car yet does it feel diffrent?
Old Jun 28, 2006 | 11:46 AM
EvoDan2004's Avatar
well insted of hitting 21 psi then droping to 19 then tapering to 17 to what it is now. hitting 21 psi droping to 19 19 1/2 psi and holding shoud give you an idea. but yes i notice a difference. i just did a 26 psi test. held for about 2 min. id say im good to go. lets go test it out again now that im boost leak free. im so happy i did this
Old Jun 28, 2006 | 02:33 PM
zze86's Avatar
you can usually test for leaks with 5-7psi. What they're doing now is pressure testing their system. in that case you usually want to test it at the same psi as what you're going to run.
