mitsubishparts . net NEED HELP
Old Jul 3, 2006 | 11:04 AM
EvoDan2004's Avatar
ok i need a under hood heat shield. not the vent of the hood but the silver thing that protects the hood. i was on mitsubishiparts.net prt number MN126274. but im not shore if it is for a lancer or the evo. maby you can help.
now also on the same site i need trans fluid, tcase fluid, and rear diff fluid. it is an 03 evo 8 5 speed. if you go to where there fluids are, are there fluids the right one's or no. i want to use oem. i went to the dealer and they want 289 to change the fluids plus the coust of fluid witch was almost 375 bucks. i was told 250something for the diaqueen and something else for the trans. mitsubishiparts.net has fluids for much less and i can do it my self. but are they the right fluids??????????
thanks to anyone that can help me out.
Old Jul 3, 2006 | 11:26 AM
EvoDan2004's Avatar
bump.
Old Jul 3, 2006 | 11:37 AM
Spec'd's Avatar
I've ordered plenty of parts there.
Usually I call them, get the part numbers and then order on line.
Use the Mitsubishi Diaqueen LSD for the T-case and Rear LSD.
Use GL4 for the transmission. I prefer Redline MT-90 and MTL.
$375.00 is ridiculous, I just did mine for a cost of about $80.00.
Old Jul 3, 2006 | 12:29 PM
EvoDan2004's Avatar
anyone. also if you got one for sale il take it
Old Jul 3, 2006 | 12:30 PM
EvoDan2004's Avatar
are those factory used fluids. cause that is what i want to use. also what was there number. i want to call them and place my order.
Old Jul 3, 2006 | 12:31 PM
Bdub25's Avatar
I have a CF hood, so if you want the one off my stock hood, just pay for shipping and i'll give you that one.
Old Jul 3, 2006 | 12:33 PM
EvoDan2004's Avatar
il take it. im going to pm you my number call me asap ok.
Old Jul 3, 2006 | 12:37 PM
Spec'd's Avatar
For the transfercase and rear differential.
The part number for that is MIT 3775610
http://www.teamrip.com/Evolution.html
Old Jul 3, 2006 | 12:39 PM
EvoDan2004's Avatar
nice il put it in and see if it comes up on the site.
Old Jul 3, 2006 | 12:44 PM
EvoDan2004's Avatar
35.00 bucks???????????????????????????? is this right. i was told like 200.00+ and i can only by it in a 5 gallon jug. or is that the trans stuff. i hope this is the right stuff for the evo.
Old Jul 3, 2006 | 12:47 PM
Spec'd's Avatar
If you want to use Mitsubishi transmission oil GL4, Mitsubishi only sells that by the drum. Most dealer usually by it in bulk.
I just use the Redline - (2) qrts MT90 GL4 (1) qrt MTL.
There's alot of debate on transmission oil, some prefer Syncroshift or Syncromesh.
Those may be good, but they're not GL4. Mitubishi reccommends GL4 in the 5 speed transmissions. This is in the owners manual.
Old Jul 3, 2006 | 12:49 PM
Spec'd's Avatar
The Diaqueen GL5 LSD can be bought in the gallon can.
The GL4 transmission oil has to be bought by the 5 gallon jug.
EvoDan2004's Avatar
ok so that must be the expencive stuff. i can only get it in a 5 gal drum. yea that is y i want to stay stock with my fluids because or all the rumors going around. thanks alot man.
Old Jul 3, 2006 | 12:50 PM
EvoDan2004's Avatar
how much do you think il need. 2 gal enoff?
Old Jul 3, 2006 | 12:51 PM
justchil's Avatar
You need to stay away from the dealership. You can get BGI or BGII for around 40 bucks (transmission) and Diaqueen for 30-40 (transfer/rear diff). You'll also need some sort of fluid pump to make the job a lot easier.
You don't have to buy at mitsubishiparts.net.. Buschur, TeamRIP, Lancershop, TRE etc etc all sell this fluid.
