Diverter valve tech.
Old Sep 30, 2006 | 05:07 AM
SaabTuner's Avatar
Originally Posted by Mike@Forge
Speed Density systems are typically setup as closed-loop systems from the factory, but they can typically use either a recirculating OR atmospheric valve without any major detriment to the system.
MAP based systems (manifold absolute pressure) are typically capable of allowing for the use of either valve as well, but most MAP-based systems are fully stand-alone and require significant tuning to overcome any changes.
MAP = Speed-Density
BPV function is simple: when there is a large pressure-drop across the throttle, the engine is eating much less air than the turbo wants to feed it, so the surplus air must go somewhere.
For small changes in throttle, it can just temporarily build up as pressure in the pre-throttle pipe until the turbo slows down. For large changes, it has to be vented somewhere to prevent compressor surge.
Simple, eh?
Old Oct 1, 2006 | 04:33 PM
boostinjuice's Avatar
I have a stock evo 8 with the MAF system running18 psi and then tappering off by redline.. If I plan on running 22psi..and getting a mail in flash.. Would it be possible to run VTA valve after the mail in flash? Amd if so.. What "bypass valve" should I use?
Old Oct 1, 2006 | 04:57 PM
PA-silver03evo's Avatar
Good write up! So often there is mis information floating around here so its nice to get a good truthful write up that can educate everyone.
Old Oct 1, 2006 | 05:22 PM
cfdfireman1's Avatar
No!!
NO
Old Oct 1, 2006 | 05:44 PM
Batmann!'s Avatar
Mike, I will be running a 50 trim turbo kit on the stock ECU / MAF(?) with a piggy-back (UTEC). I am looking for a BOV that can hold high levels of boost (30 psi). I also don't want any stalling, fluttering, or driveablility issues. What BOV would you recommend for my application?
Old Oct 1, 2006 | 05:56 PM
Cool mike from FORGE
i wonder what mike from FORGE wil say?
Old Oct 1, 2006 | 06:32 PM
Originally Posted by cfdfireman1
NO
y?
Old Oct 1, 2006 | 06:42 PM
Question http://forums.evolutionm.net/search.php?
y?
https://www.evolutionm.net/forums/search.php
VTA valve & "bypass valve" 2 dif things. read my friend till your eyes bleed.
Old Oct 1, 2006 | 11:04 PM
NiteRider's Avatar
I put an HKS SSQ BOV on a few days ago and ran it for a day and noticed my car was running rich. I took it off the next day and put my stock DV back on and I'm noticing a flutter from the stocker. I never heard anything before I put the HKS on and now my mileage is not as good anymore and I am still feeling jerkiness. I have reset the ECU, I don't know what else to do. This thread has definitely helped me to realize the advantages/disadvantages to using certain valves.
Old Oct 2, 2006 | 07:16 AM
https://www.evolutionm.net/forums/search.php?
so i need a re circulating valve whether or not i have it tuned ..becuase i have a MAF?
Old Oct 2, 2006 | 07:46 AM
yepper
Old Oct 2, 2006 | 12:33 PM
I'm so confused. I thought you could get a VTA as long as you had your ecu tuned to a VTA valve.. And I have seen other evos with VTA valves and runnin just fine becuase they got it tuned
Old Oct 3, 2006 | 05:26 AM
troe666's Avatar
whether this is relevant or not, hopefully it adds something, generally if it's VTA, you obviously adjust the spring tension so that the BOV does not open from idle rpm pulses and yet opens sufficiently when coming off the throttle at all on-boost rpm points. Some people alter spring tensions to adjust the sound of the valve independently of the nozzle/outlet. This is because at a tighter spring tension you'll get a shorter, sharper sound, whereas with a looser spring tension you will encourage actual turbo 'flutter' sound through the air intake as well as cause a lower frequency and often sporadic/staged exit of air through the BOV.
Any BOV without a spring tension adjustment should not really be moved from car to car as compromises will be the sound will change when you move it (at best) or the car will stall badly as you pull up to idle
Trav
Last edited by Fourdoor; Oct 7, 2006 at 08:38 AM. Reason: remove reference to crap in thread
Old Oct 6, 2006 | 04:18 PM
bluevo8urV8's Avatar
is it posible to "crush" the mr bov to get it to hold more boost? i remember on my 1g talon i crushed the stocker and it held alot more boost.
Old Oct 6, 2006 | 06:33 PM
trinydex's Avatar
yes it is but you likely wouldn't need to and wouldn't want to for applications beyond the mr valve's capabilities you'd want to do something like a dejon tools leak stop kit mod.
why does anyone think that a leak at idle is good or is normal?
