Arizona Forced Induction 42r setup...Completed pics..
Old Jul 27, 2006 | 07:17 PM
  #61
FastCoEVO's Avatar
that looks alot like Peak Boosts top mount kit
bad *** work though
Old Jul 27, 2006 | 07:54 PM
  #62
CO_VR4's Avatar
I'm interested in some real world data on how the much smaller radiator works to keep temps in the acceptable range with more than a few seconds hard use... please let us know what you find as the characteristics of the setup are explored.
Old Jul 27, 2006 | 09:19 PM
  #63
ct9a gsr's Avatar
Just curious, are there any braces or support brackets welded to any part of that setup to help support the sheer weight of the turbo on top of the manifold? If not, are you all worried about possible damage from the stress the weight of the turbo has? If so, where are the support brackets welded from and to? I'm curious 'bout your setup, looks amazing.
Old Jul 27, 2006 | 09:39 PM
  #64
jbrown's Avatar
nice ride, looks very well done with a lot of attention to detail.
bravo!
Old Jul 27, 2006 | 10:04 PM
  #65
M10's Avatar
M10
Is there any room to mount an intake to that turbo?Seems like the upper radiator hose is in the way.Since it's going to be a street car,aren't you worried about debris getting sucked in?
Old Jul 27, 2006 | 10:30 PM
  #66
silverofs's Avatar
wow it takes alot of work to make that setup work..... congrats on the whole setup it is badass!!!!! i love top mounts
Old Jul 31, 2006 | 08:24 PM
  #67
gaijin's Avatar
bad *** work though
yeah that's kinda funny considering that AZ-FI finished my kit first.......
Old Jul 31, 2006 | 08:26 PM
  #68
gaijin's Avatar
That is currently the only issue and it is being addressed. It also didn't help that it was being driven around in 120 degree heat in Phoenix, but that's one of my goals for the car. I want to be able to street drive it in the summer with the a/c on and still be able to smoke anything on the road.
Old Jul 31, 2006 | 08:48 PM
  #69
smp3000's Avatar
Almost ready????
Old Aug 1, 2006 | 12:48 AM
  #70
12mnkys's Avatar
Reid...if you talk to Jesse have him call me. I want to get my car in to get finished up...i couldn;t reach him last week!
Thanks bro,
Mike
Old Aug 1, 2006 | 12:59 AM
  #71
housedj's Avatar
i hope he can get the cooling issue resolved. that radiator is the size of a fart bubble & the car can't even be dynoed cuz it will overheat. studying the car at the last dyno day out there in Mesa, Reid should ditch the CRX radiator & have 1 made thicker. there is room, OR he can removed the heater condenser & replace it with a radiator almost stock size. i also mentioned to him that a low temp t-stat would help as well & get rid of the extra fan blowing hot air on radiator.
i also think all that power is going to dip the rear so much that it will cut his rear 275 tires clean off!!
i also suggest he slap that barrel h20/meth kit on at the Mesa shop on his car as well. water/meth might be the only other way to help cool "the Blackbird"...
Old Aug 1, 2006 | 09:00 AM
  #72
jmartinez1170's Avatar
Im i the only one that see's the hks intake manifold will see how much hp this thing lays down.
Old Aug 1, 2006 | 10:12 AM
  #73
AFI Turbo's Avatar
The radiator is the same size as the AMS cars run...its a stock duel core civic radiator. The car wouldn't heat up in Chicago, NY, etc...when its been in the low 90's the past few days the car doesn't run hot...120 deg temps and blazing sun is alittle different story...either way we had a custom size core built and sent some parts to swaintech...
Old Aug 1, 2006 | 11:50 AM
  #74
CO_VR4's Avatar
I was just interested if, for example, you could drive the car in spirited use for 20-30 minutes straight and not overheat, or whether a couple minutes would push you closer to the envelope than you'd like. In other words, whether it's a primarily off throttle drive around and occasional 11 second use, or whether it would be a good canyon or mountain car as well....
Old Aug 1, 2006 | 12:08 PM
  #75
12mnkys's Avatar
Jesse,
get back to me if you can...I want to schedule with you a time to finish up the water/air kit. let me know.
Thanks,
Mike
